Nvreloader
Western Nevada
- USA
Guys
I am heading down this path for a little modding on my MD 750 MD Wart Hog,
I want to add a complete set of front & back 24" Fat tire wheels with a semi Hiway road type tires,
if I can find them.
I believe that I have to match these spec's of the 26" Fat tire wheels that are OEM stock now,
in the 24" wheel set.
I am checking all the Fat tire hunting bikes to see if there is a 24" size, that will work.
26" wheel spec's
Front Hub:
15mm, 150mm Hub Spacing
Gear Shifter:
Sram X-5 9 Speed Trigger Shifter Right Hand
Rear Sprocket & Derailleur:
DNP 13T-34T / Sram X-5
Rear Hub:
197 mm Hub Spacing Bearing, Quick Release.
Brake System:
Tektro HD-E725 4 Piston Hydraulic 203 mm Rotor.
Tire:
Kenda Juggernaut 26*4.5''
Rim:
Aluminum Alloy, Double Wall, 100mm Width, 36 hole/spokes
Your thoughts and suggestions.................... On how you would do this.
Tia,
Don
if I can find them.
26" wheel spec's
Front Hub:
Gear Shifter:
Rear Hub:
Brake System:
Tire:
Rim:
Tia,
Don
