Brake Rotor Upgrade for Himiway Cruiser
Proteusmym
I would like to change out the 180mm front brake rotor to a 203mm rotor. Anyone done this? Any special or unique procedure? And, which 203mm rotor works on the Cruiser? Also, I am using the Juin Tech M1 hydraulic caliper. Which caliper adapter do I need to install for the 203mm rotor? Thank you for any help.
I thought about doing this too - I believe the existing brakes has a 160mm to 180mm adaptor already to mount on the fork. So ideally you would get a 160mm to 203mm adaptor, rather than stacking them.
its not a good idea puting a 203mm rotor onto a fork not designed to take that extra braking force. I would pout on high quality housing first if your having trouble stopping.
