I unexpectedly ran across some very weird brakes on a kid's bike a grandmother is giving to her grand daughter for Christmas. It was an afterthought after making a house call to tune her adult eTrike. How hard can it be to adjust a front rim brake? The weird brakes are called 'SureStop'. They use a single lever on the right to activate both front and rear rim brakes. The front cannot be adjusted in the stand. The right rear pad was locked up. I had to take it apart and lube inside with wax. The proprietary right rear pad slides in the direction of rotation, pulling the front cable. It is a huge mess to adjust correctly. Parts including a special cable are proprietary and do not work very well. If you are assembling kid's bikes this Christmas be ready for them. Normal parents will never be able to work on these. Kids will crash.
Indeed, the PB Swiss set is 10+ years old. Have been used in the workshop for years and besides that I keep them clean there are some spots in the paint but the working ends are still perfect. I just the the 3 replaced cause it was bend. I do hope the new set lasts.previous set was 6 ish years old and not that much used but the most important sizes were toast
My favorite aspect of the ball end is that it's sort of self-guiding, like a crosshead screwdriver. That makes it a quick way to see if I have the right size.
One compact set (like yours) seems to do everything on my bike but the rear axle nuts. The screw that hangs the front fender and headlight is a problem because there's not room to use the long end as the handle. That's OK. The ball end is strong enough for that, and I can give it enough torque turning the short end.
I had to make a short one.
I made a short one using my brand new bolt cutter more than 20 years ago,..
That's when I learned that you can't cut tool steel with tool steel.
I did actually get it cut on the third try closer to the fulcrum, but my bolt cutter wasn't too happy about it. 😁
I drilled a Big F-in hole in the side of my 🏠 today.
The hole saw got jammed in the hole and my drill spun around backwards four times before it finally stopped.
It made skid marks on my siding, and scrubbed halfway into the lithium cellpack.
I Coulda Blowed Up !!!??
I don't like playing with tools that bite too hard.
Circular saws make me Real Nervous. 😁
I just bought a 32 pound bench grinder last week.
It doesn't scare me at all !!
After sharpening a few knives, and drill bits, I did my nails 💅
I seriously sanded down all my ten fingernails.
Took like 10 seconds flat.
I saw a sign on my way to get groceries yesterday.
$30 for a manicure.
My grinder was on sale for a hundred bucks.
It does pedicures too, so I'm gunna get my monies worth. 😁
New short and angled quality hex wrenches to complement my PB Swiss Rainbow set. The old cheap short head wrenches worn out so time for an upgrade.
Those are used for bolts on hard to reach spots.
These ball end wrenches are great for most bolts. Occasionally though, I'll find one with a shallow socket. The ball end will bottom out before it fully engages and can strip the hex socket. Just something to be aware of.
Back when I was young and stupid (78), I put a 25mm spade bit in my drill. I attached the handle so it wouldn't break my wrist if the bit snagged. I began drilling holes in a dogwood stump to make it easier to chisel flush with the ground. When I hit a rock, the drill yanked me forward into a somersault.
At 79, I hit another rock drilling another stump. This time I was older and wiser. It didn't flip me because this time I was sitting on the ground. The bit was beyond repair, though.
I bought a 150g grinder for manicures and pedicures.
I've sharpened with a bench grinder. For knives and chisels, I prefer my 2-pound 1/2" belt sander. Speed control. Quick change of grit size. Excellent angle control. Portability.
For mower blades, I prefer a 5" angle grinder with flapper disks. Speed control. Quick change of grit size. With the side handle, excellent angle control. A sharp blade is gratifying when I want leaves to disappear.
