I unexpectedly ran across some very weird brakes on a kid's bike a grandmother is giving to her grand daughter for Christmas. It was an afterthought after making a house call to tune her adult eTrike. How hard can it be to adjust a front rim brake? The weird brakes are called 'SureStop'. They use a single lever on the right to activate both front and rear rim brakes. The front cannot be adjusted in the stand. The right rear pad was locked up. I had to take it apart and lube inside with wax. The proprietary right rear pad slides in the direction of rotation, pulling the front cable. It is a huge mess to adjust correctly. Parts including a special cable are proprietary and do not work very well. If you are assembling kid's bikes this Christmas be ready for them. Normal parents will never be able to work on these. Kids will crash.
Indeed, the PB Swiss set is 10+ years old. Have been used in the workshop for years and besides that I keep them clean there are some spots in the paint but the working ends are still perfect. I just the the 3 replaced cause it was bend. I do hope the new set lasts.previous set was 6 ish years old and not that much used but the most important sizes were toast
My favorite aspect of the ball end is that it's sort of self-guiding, like a crosshead screwdriver. That makes it a quick way to see if I have the right size.
One compact set (like yours) seems to do everything on my bike but the rear axle nuts. The screw that hangs the front fender and headlight is a problem because there's not room to use the long end as the handle. That's OK. The ball end is strong enough for that, and I can give it enough torque turning the short end.
