Range Variation with Temperature
S.Giles
Other
Hi all,
Has anyone else noticed a considerable reduction in battery range in cold weather? About eighteen months ago (in warm weather) I measured the range of my Engwe L20 Boost at 50 miles on a single battery charge. Today I was down to a single bar (out of five) after about 14 miles (at about 10*C).
I'm trying an experiment tomorrow. I've brought the battery indoors to warm it up to room temperature and I'll see what the range is when I do the same journey in the morning. I'm expecting an increased battery range, since the battery core will take time to cool down to ambient temperature.
Your thoughts on this subject would be appreciated.
Steve
Hi all,
Steve
yes, i've never done a full range test but anecdotally i get less range and the overall takeoff speed is less zippy, i also keep my battery inside the house (rather than the garage) on cold days before i commute and noticed that helps a lot. my commute is under 20 mins. ive kicked around buying a battery thermal wrap but i bike commute less in the winter and have never got around to it and keep my bike inside at my office so it is warm by 5pm when i leave.
i've heard the same thing from some of my buddies who have teslas, range goes down in winter temps.
let me know how the range goes with keeping the battery warm before riding!
Yes minus 0 cold weather absolutely effects battery range.
Bring your battery inside when it's cold. Get yourself a thermal neoprene battery cover too.
Stops battery wind chill while riding.
It is a chemistry thing. It is quicker and easier to make a cup of tea with warm water. If you have a candy store close by ask for some of the Mylar bubble wrap that chocolate is shipped in. A cover can be made using fiber shipping tape out of the stuff. If vented it also makes for a great hat liner and it has the upside of keeping aliens and intelligence agencies from reading your thoughts. It is like an insulated Space Blanket for your battery. Candy stores chuck the stuff everyday.
Steve, 10 C is only mildly cold. Battery University's Li-ion figures are roughly 83% of capacity at 0 C for an energy cell, so at 10 C you'd lose much less than that, nowhere near 50 miles down to 14. Cold alone probably isn't the whole story.
Most bar gauges read voltage. Cold raises internal resistance, voltage sags under load, and the bars drop early, then recover once the pack rests. So note the resting voltage after a full charge and again an hour after the ride; that tells you far more than the bars. If it's well below the usual full voltage after an hour's rest, suspect ageing or a weak cell group after 18 months.
Keep the test fair too: same assist level, tyre pressure and route, and charge the pack at room temperature rather than in the cold.
Thank you for the reply.
Yes, the two tests weren't comparable. With hindsight, it was unwise to make the 50/14 comparison. The Engwe L20 Boost has a 'Boost' button that can be used intermittently to deliver short bursts of full power (at the expense of range). The original (50 miles) test was done with no use of that function, whereas yesterday I did use the button because the bike seemed so sluggish right from the start.
Indeed, as you suggest, there was a noticeable amount of voltage sag that later recovered after a period of rest. I've never seen this before to such a degree. Normally (ie, in warmer conditions) voltage sag is almost completely absent.
And one other small point (lol). I was pulling two trailers (see my other thread). Before someone accuses me of being an idiot for expecting similar battery range under such conditions, please let me explain. The very rapid voltage drop was noticeable _before_ the trailers were loaded, on the journey out and after just a few (maybe ten) minutes of riding. The rolling resistance of an empty trailer is not that great. I use trailers a lot, so I wasn't expecting to see such a quick drop in battery voltage.
Anyway, I'm doing the same journey today, having brought the battery into the house overnight to warm it up. I'm looking forward to seeing if there's any difference in performance.
Another consideration:
Well-used lithium batteries are generally more affected by low temperatures than new ones. As a lithium battery ages, its internal resistance rises and its remaining active lithium and electrode surface area shrink—meaning cold weather takes a bigger bite out of both its usable capacity and voltage under load.
Maybe this is off-topic, but I power an additional front light with two old Nokia phone batteries wired in parallel and held together with duct-tape. I would estimate they are about twenty years old. This makeshift battery pack fell off my bike one day and I couldn't find it, despite searching for it all along the route I had taken. Then one day, about six or nine months later, I glanced down as I was riding along and there it was, looking somewhat shabby because it had been lying on the road in all weathers for months. It must have been run over many times by passing vehicles and been soaked in rain dozens of times.
Long story short; I took it home, charged it up, put it back on the bike and it works perfectly to this day.
Also take note... That you yourself are probably putting out less on a cold day. I know when I'm wearing extra clothes and feel cold and a little stiff... l'm dragging ass compared to a spring day ride in shorts. The less you do, the more the battery has to and with the cold affecting it as well the drop can appear to be significant.... though no where near what you originally described.
That said yesterday was my coldest ride so far this year with the temp around 9c and this morning my battery was 1.v higher than normal after the typical near identical ride.. So wtf do I know 🙃
I did more or less the same ride today, having kept the battery indoors overnight. I arrived at my destination with four (out of five) bars left on the battery, as opposed to two bars the previous day. Therefore no range anxiety today.
Conditions were not exactly the same as the previous day. Temperature was a little cooler, but no headwind today, and I tried to lay off the Boost button a little more.
My impression is that warming the battery made a huge difference.
I always thought the energy loss was due to Pleukert's law, and at a colder temperature, his constant would be higher. This article says it's a misconception that energy is lost. Should I believe it?
Peukert's law has minimal practical effect on lithium batteries compared to lead-acid batteries, though it is sometimes modeled for them.
Key Takeaways for Lithium Batteries
    • Low Peukert exponent: Lithium-ion batteries typically have a Peukert exponent around 1.0 to 1.05 (compared to ~1.1–1.6 for lead-acid). A value near 1.0 means usable capacity changes very little at higher discharge currents.
    • High efficiency: Lithium batteries generally deliver 95%–98% of their rated capacity across normal discharge rates, whereas lead-acid batteries lose noticeable capacity under heavy loads.
    • Different drop-off behavior: Because Peukert's law was originally developed for lead-acid cells, a simple fixed Peukert equation often breaks down at very low or very high currents for lithium cells. At heavy loads, voltage drop from internal resistance and heating plays a larger role than a classic Peukert effect.
    • Practical limitations: Peukert's equation assumes constant current and temperature and does not account for aging or variable loads. Opinions on Endless Sphere are mixed on using a Peukert constant for lithium batteries, with some users noting exponents roughly between 0.99 and 1.09 while others argue resistive losses and variable loads make it less useful for lithium packs
Hi all,
Steve
I noticed it at 6 degrees C, the bike was down on power and I used 5 bars in15 miles on pretty well flat ground.
My old Hailong battery is practically useless at 1 degree C, easily down 50% in power.
Yes, there is some degradation of the e-bike battery in low temps but it is not as dramatic as one might think (if we talk about quality batteries). That's why:
This e-bike was exposed to -3 °C (dropping as low as -5 °C) for 5 hours and 45 minutes, yet both the battery and motor maintained comfortably positive temperatures during the ride. Why? The motor operates at 79% efficiency, meaning up to 21% of the battery's energy goes into heating the motor. Meanwhile, the battery is well-insulated inside the down tube, and its internal resistance naturally generates heat under load. While warming the battery does consume extra energy, the total range loss in moderate frost is likely around 15%.
Ok guys,
I know about of battery covers,
But my problem is finding one the has enough wrap around circumference of 16-18",
and overall length of 22"+, and another one that is 28" in circumference and 22" long,
to fit Dual OEM battery setups.
I need 2 different sized covers to fit my 2 bikes, and can't find any so far, that will work.
I have been using a 18" x 16" long/circumference neoprene 1/4" thickness, belly band,
but it stills let the cold air on both ends.
Cold weather/air has arrived here, 10* in the am/night time hours.....
Any thoughts or suggestion would be greatly appreciated.........
Tia
Yes I remember well your quality battery needing to be kept outside and then disposed of because it stayed warm even off the bike.
Didn't another cause quite a bit of fire damage... cough, cough, NDA... caugh, cough
Ok guys,
Tia
I don't do much cold weather riding anymore, but when I do, I wrap the battery with disposable bubble wrap and hold it in place with an ace bandage. I keep a box in the shop for storing & shipping fragile items.
The ace bandage seals the ends around the down tube to keep out air flow. The bike looks like a cripple, but it's cheap and works quite well. For me anyway, there's no sense in spending money on a custom cover that isn't used much and can't be used for anything else.
I had some of this left over from a construction project and have used it in the summer to keep the sun off the rear rack mounted battery.
Basically aluminiz'd bubble wrap
I didn't seal the ends so it allowed air to flow under it
If I remember correctly it kept the battery more than 20°f cooler and near ambient temp. I see no reason why it wouldn't be great in the winter.
That said my winter rides are >25 miles so I don't bother
