Chargeride
I thought only Gusset brake levers have a crotch screw
It worked on a giant trike with hydros this week. It pushed the lever out for more pull.
Not sure if we are talking the same thing but TRP (Tektro Racing Products) brake levers have not just an adjustment screw but a screw that you can operate with your fingers even on a ride.I thought only Gusset brake levers have a crotch screw
It looks your joke fell flat like a Russian fighter plane in a Zelensky memeJokes are fragile things, it just takes one earnest attention for them to turn into dust.
Im more concernrd that the word gusset is being removed from its classic reference.It looks your joke fell flat like a Russian fighter plane in a Zelensky meme"I wanted to tell you guys a joke about a Russian fighter plane but it fell flat".
You don't need to be "wittous" all the time
Did I say that before? When I was a kid, my Mum (who was a scientist) said: "Acids can be strong as the sulphuric acid or weak like the sulphurous one. Some people are just witty. I hate the wittous ones".
Any reason not to be serious or practical?![]()
The Maguras have a tiny set screw with an Allen head that does the job.Not sure if we are talking the same thing but TRP (Tektro Racing Products) brake levers have not just an adjustment screw but a screw that you can operate with your fingers even on a ride.
Initially, you set the brake lever position so it matches your fingers' length. As the brake pads wear, you feel the lever becoming mushy. Several turns of the screw with your fingers, the lever returns to the preferred position and becomes firm again. I could not find such a screw on other brand brake levers but well my experience is limited in this field.
Theyve made an entire brand without anyone but me smirking.
,.. changes the resting distance of the brake lever blade relative to the handlebar grip.
I use those Drift Mechanic "Maniac" freewheels all the time. They are beautifully polished nickel plated, are not expensive, and come in 11-34. They are so much better than the Tourney ones that come as original equipment on so many hub-drives. It just requires a mid to long cage derailleur. On @Go-Rilla's bike one big improvement would be a Mico-Shift push-push trigger shifter.Drift Maniac DNP freewheel
