concerns with ebikes laws and ways to improve them
There needs to be incentives for not using any motors at all.
Bikes are still ridden for leisure/recreation/fitness but transportation solutions do have time and efficiency components. Sure average ebike speeds are higher than traditional bikes but that is very very important when used for mobility. Also ebikes are the most efficient way for humans to go from A-to-B when total energy and calories are considered - as efficient as a full loaded passenger train. No one is trying to belittle you but you are saying some things that seem like intentional disinformation - you never want to appear to be a troll with a hidden negative agenda (ie propaganda in harmful).
You clearly just don't like ebikes. A good rider on a traditional road bike can sustain a speed over 30mph on a level surface for at least a few minutes (….
absolute nonsense, and e-bike advocates need to stop using falsehoods to make their case.
it takes over 600 watts to go 30mph on level ground on a decent road bicycle. check the CAT charts for RACERS and you’ll see that this is sustainable for about a minute for a 75% category racer. for an amateur, enthusiastic and fit rider, more like 30 seconds. the average speed for enthusiastic recreational cyclists is 12-14 mph with extremely few sustained periods over 20mph.
unless you want to license, register, and insure cyclists and cycles, and build out an appropriate independent network of streets and paths suitable for whatever random vehicle you have in mind, e-bikes need to stay close to the performance envelope of a high level recreational cyclist. that means 15-20mph, not 25+, and it means 250w sustained, not 750.
you keep saying the same (often untrue or irrelevant) things over and over again, so please don’t bother replying.
You left out my row at the bottom.
What does the 1st (%) column refer to, and where can I find an explanation of this chart?
At 77, I can easily go WAY faster than anyone should on an MUP on a 40 lb, 250W, 35 Nm ebike with no throttle. In ECO or even in OFF.
For legal ebikes granted full access to public trails and bikeways, 750W of motor power, however measured, is more than enough.
At 77, I can easily go WAY faster than anyone should on an MUP on a 40 lb, 250W, 35 Nm ebike with no throttle. For legal ebikes granted full access to public trails and bikeways, 750W of motor power, however measured, is more than enough.
the first column is the percentile rank of athletes on cyclinganalytics - so if you read across from 90% basically 10% of athletes on that site can sustain 627 watts for a minute. so really we’re probably talking about 1 to 5% of the population, because anyone using a power meter and uploading to cyclinganalytics is by definition a pretty committed cyclist.
You are misunderstanding disagreement for a failure to understand. Fact is, people are pretty smart here insofar as discussion participants are concerned (although we concurrently prove our stupidity by trying to talk to the brick wall that never listens).
Years into this, the relevant legislation and regulations have been read and understood. The arguments you push have also been read, digested, understood... and rejected.
After all this time and all of these thousands of pointless words, you know this.
Really? I have read many threads and almost all seem to think the max ebike motor power is 750W. There is nothing in HR727 or the 3 class legislation that says that even though that is what non technical people believe both state. When the wattage of a motor is stated it's always a RATING...not a maximum. The guy that wrote HR727 was a PhD Electrical Engineer who would have inherently known this - the max wattage would have to be set by the design and programming of the controller. When Dr. Currie wrote HR727 he intended to allow more than 750W below 20mph to allow solutions like cargo ebikes. The NHTSA was not concerned about max power below 20mph - they were just not wanting to allow speeds above 20mph under motor alone.
In the same vein, HR727 does not set a max assist speed of 20mph. Read that again!!!! It just states the power above 20mph can not provide for speeds over 20mph on a level surface which means that level of assist can continue with higher speeds being enabled via rider power.
These are technical reality but I have read very few people commenting with this knowledge. This is not "rejectable" information - it's FACT if you understood engineering specifications.
Its worth noting that Ken is not an ebike advocate, hes a zealot for the early 2000s CPSC ebike definition only, and cares about almost nothing beyond that.
You know that for years I said this current mess was going to happen because it was the intend of the 3 class legislation from People for Bikes. I stepped away for some time and have recently decided to engage again because what is going on is irrational and soon we'll end up with ebikes being back under the NHTSA with reguirement for VIN numbers, headlights, blinkers, etc. and use regulated with licenses, registrations, and insurance. WTFU...I'm the one putting myself out there to keep HR727 compliant low speed electric bicycles treated as bikes by state use laws which was exactly what was the case for many years before the 3 class legislation.
I'm a huge advocate of ebikes. I am a zeolot of HR727 approved in the early 2000s because it was written by a PhD Electrical Engineer that had political capital (Currie was CEO of Hughes and Delco) and knew the auto industry would see them as a threat. I have had a conversation with the Lawyer that worked with Malcolm Currie for years to get this legislation passed when few ebikes existed and the auto industry was really paying attention. He would know the intent of the bill and how challenging it was to get passed. The expressed preemptive clause is very rare and it was a statement to deny allowing states establishing more stringent definitions for ebike. Why don't you read some legal papers on a preemptive clause being used like that. Don't lecture me like I'm the troll when what I'm saying is true.
The category charts for racers are 100% bullshit. I can't say that enough. I've actually done races averaging over 30mph for over an hour. Have any of you? I did not average over 600 watts. Not even close. Racing is not a steady state activity. Put those charts back in the trash bin where they belong.
Feels like we're missing an important piece in this puzzle. Can't argue with your experience. But in theory at least, steady speed (no accelerations) is the most energy-efficient path to a given average speed on a given course.
I can't speak to cat charts for racers, but broadly some ebike advocates like to vastly overestimate the speeds that roadies ride at and power they output when arguing for allowing more speed on ebikes. I mean, sure, best in the world pros can output 400w for an hour, but thats extremely unusual. I've looked at various strava segments and the really competitive ones in my area (with thousands of rides) tend to be in the 250w (longer) to 400w (shorter) for the absolute top riders. 750w of output is a lot of power compared to normal riders. 250w is actually a lot compared to normal riders!
Actually if you are into hyper-miling and ebike the Sweet Spot is 10-12mph.
And it isn't a coincidence that long-distance bike tourers converge on an average speed in that range.
Once you go above 15mph air resistance starts to takeover from everything.
The takeover can start at even lower speeds. Using realistic parameters for 195 lb me in lycra on my 38 lb Vado SL 1 on smooth flat pavement in still air, the "crossover speed" Vc (at which air resistance becomes half of total resistance) is ~12 mph (5.4 m/s).
Vc grows with total (rider+bike) weight, gradient, surface roughness, or tire sinkage. It falls with a headwind, upright posture, baggy clothes, or bulky cargo.
Yeah, I've always heard ~15mph is the point where rolling resistance stops being the majority of whats holding you back and wind takes over; that speed probably varies a lot depending on bike setup (how low your rolling resistance is and how aero your setup is). But thats the reason that bike racing disciplines that don't allow you to sit in a pack place a huge emphasis on aero.
Worth noting in the moderately aero example I gave above that air resistance is still 25% of total resistance at 6.7 mph (a common climbing speed) and 12% of total at 4.5 mph — which for many is close to minimum balancing speed.
For an upright commuter in street clothes on slower tires with panniers or a big trunk bag, crossover speed would be considerably lower than 12 mph.
Bottom line: Air resistance is seldom negligible. Tight-fitting cycling clothing can reduce it by up to 20% at all speeds.
I can't argue with that point regarding efficiency. For races like an ITT or long ones like RAAM, efficiency is important. All sorts of efficiency. Aero, pedal motion, hydration and nutrition, etc. Other than aero, about the only thing related to efficiency when racing a four corner criterium is being completely wasted when you cross the finish line. The whole race is hammer-rest-hammer-slow-corner-HAMMER-rest ad infinitum.
FWIW, when I had an analog hybrid bike (2019 Cannondale Adventure 1) my speed was 12-14 mph. Now, I ride a class 3 Specialized Turbo Vado SL where my average speed on the same trail is 14-16 MPH. I suppose if I had a regular Turbo Vado that is much more powerful I could sustain higher speeds, possibly even the class 3 top speed of 28 mph.
That’s the point in these discussions. Bicycles can be ridden at speeds from 3-4 mph for kids and older slower adults up to 30-40 mph on the flats for strong amateur or pro racers. (Flats is the important word. Uphill bikes go slower. Downhill speeds can be much, much higher.) Writing regulations for MUPS, bike lanes and rail trails is incredibly complicated and fraught with conflicting interests and levels of comprehension. It’s the nature of legislating. I mentioned in another thread that I’m seeing better reporting on bicycle issues: reporters are differentiating between bicycles, e-bikes and e-motos and stating that the problems are almost always e-motos often ridden by irresponsible teenagers. (Irresponsible is redundant. Teenagers are by definition irresponsible.)
As Ken M always points out, it’s assist up to 20 or 28 mph on a flat road with no assisting wind. Above those speeds human power only is required. His point is that these speeds can be reached with assist from motors of a wide range of wattages. A 30 pound e-road bike needs much less assist power to reach 28 mph than a 60+ pound fat tire bike in the same conditions. If there are speed limits on bike trails, who’s going to enforce them and how are they going to monitor the speeds.
So, speed limits don’t really work for bicycles. That’s a reason why People for Bikes came up with the three classes. I agree with Ken‘s reasons on why the three classes are unnecessary if the e-bike definition he touts are used. I think the classes are actually for consumers. The 20 mph limit seems less frightening than 28 mph for many people. (I’m not opposed to throttles in general. Heavy e-bike riders can need the help getting started and folks with various disabilities can require a throttle in order to ride at all.). The class three bikes can be considered an educated choice by those who feel the extra couple of mph are safer on the road or more fun. I am presuming that cyclists are reasonably law abiding and considerate of others.
Air drag is proportional to the square of the airspeed, so if you're traveling twice as fast (whether you're actually going twice as fast or you're going, say, 10 mph into a 10 mph headwind) it's four times the air drag.
