Archon X1 Programming Thread (questions and experiences)
The new generation of the INNOTRACE controller is coming!
I played around a little bit and was finally able to connect via VESC Tool to my Innotrace X1!
Can this be used to fine-tune thumb throttle sensitivity? ("start", "end", in millivolts - like on BBSHD) I'm about to do an Innotrace build, and I've tested my friends one - his thumb throttle has wayyyy too much deadzone..
How about field weakening, I think I heard somewhere that there is very little field weakening applied on the Innotrace. Can it be tweaked further?
edit: from earlier post, the field weakening tab is empty??? XD what is this
If you are planning to build the VESC for Bafang M620 UART controller you better to be sure you are familiar with VESC stuff. There are only a few VESC guys claimed they were able to make that VESC firmware works on that controller and they refuse to share the instructions. But if you will make it works please post the instructions here.
If you want to build the new INNOTRACE M620 CAN controller then it has all the options the VESC firmware offers including tuning the throttle and modifying the source code to achieve any behavior you want.
The field weaking tabs are empty because of it is new VESC Tool while the INNOTRACE X1 firmware is based on quite old VESC firmware Krasnodar used.
