Archon X1 Programming Thread (questions and experiences)
Any ideas why my original Innotrace X1 throttle works only for the first time? if I go full throttle, and let go, I can not use the throttle again (any speed), for a while. The first time it feels good and logical and smooth, after that, dead for a bit.
- tried two displays
- tried two throttles (known-good from my BBSHD)
- did encoder calibration with the X1tool
- (happens on the road too with proper load)
Video:
Does it also do it if you dont open the throttle all the way?
I think it works "okay" if I only actuate between 0-25% ish.
When the throttle dies, I can keep holding it at full throttle for 15 seconds and nothing happens, until I let go and there's a reaaally small slight nudge (in the motor).
EDIT: Also, the "hidden" unlocked sports mode also doesn't seem to work (with the small display); it always starts with throttle enabled and full power.
Sidenote: this Innotrace is second-hand, I bought it used, driven 2300km. But new to me and I just finished my build. Works okay with PAS only.
edit n^5: disabled "Safe Start" with VESC Tool and it works as expected now (i think at least!), wondering if there are any side effects ":)"
edit n^5+1: back to enabled "Safe Start", root cause was my BMS having Charge FETs disabled --> back EMF voltage spikes had nowhere to go --> controller spazzed out. (VESC tool showed 2026-11-16 01:27:30: Status: FAULT_CODE_OVER_VOLTAGE)
