Archon X1 Programming Thread (questions and experiences)
Any ideas why my original Innotrace X1 throttle works only for the first time? if I go full throttle, and let go, I can not use the throttle again (any speed), for a while. The first time it feels good and logical and smooth, after that, dead for a bit.
- tried two displays
- tried two throttles (known-good from my BBSHD)
- did encoder calibration with the X1tool
- (happens on the road too with proper load)
Video:
Does it also do it if you dont open the throttle all the way?
I think it works "okay" if I only actuate between 0-25% ish.
When the throttle dies, I can keep holding it at full throttle for 15 seconds and nothing happens, until I let go and there's a reaaally small slight nudge (in the motor).
EDIT: Also, the "hidden" unlocked sports mode also doesn't seem to work (with the small display); it always starts with throttle enabled and full power.
Sidenote: this Innotrace is second-hand, I bought it used, driven 2300km. But new to me and I just finished my build. Works okay with PAS only.
edit n^5: disabled "Safe Start" with VESC Tool and it works as expected now (i think at least!), wondering if there are any side effects ":)"
edit n^5+1: back to enabled "Safe Start", root cause was my BMS having Charge FETs disabled --> back EMF voltage spikes had nowhere to go --> controller spazzed out. (VESC tool showed 2026-11-16 01:27:30: Status: FAULT_CODE_OVER_VOLTAGE)
Now that the throttle is working fine, I have two other problems:
- Hidden sport mode (by special command with the small display) is non-existent, bike starts with throttle enabled. It should be by default in all units, or am I mistaken?
- Gear shift sensor inoperational, pinout seems correct but haven't inspected further. Might it not exists in my firmware at all?
If you mean by sport mode the unlimited speed off-road mode you need activate it each time you turn the display on by pressing the buttons Down and Mode simultaneously for 2 seconds after starting the display within 10 seconds after turning the display on (if the display shows logo on start then wait until the menu will be loaded after the logo and then press the Down and Mode buttons).
You can ask Krasnodar from Ex-Force.de if the X1 controller has shift sensor functional. And also ask him meanwhile when he will make that server for X1Tool up and running he promised us to launch "soon" many years ago.
You also need a battery that can supply the amperage and power this controller demands.
It starts in unlimited speed mode without pressing any buttons. That was my question - what's up with that?
My friend has an Innotrace and his shift sensor works.
I do not know. Originally after I got the controller I did not know that it requires pressing those buttons combination and my controller had not enough power after I purchased it from INNOTRACE and I did not know what is going on and how to get the full power. Krasnodar installed another firmware and told me to press those buttons combination on the display to turn the unlimited mode on and it worked after this properly. Maybe it would work properly without that firmware installation if I would know it requires pressing those buttons.
If your controller starts always in unlimited mode maybe try to press those buttons and see if it turns it to limited mode.
If it does not work you can try to contact Krasnodar and ask him what is going on with the modes and the shift sensor. He said he can install new firmware for the INNOTRACE X1 owners. But ask him if it will work with the X1 Tool first because of you probably do not want to lost the ability to change the controller settings. And if it does not work with the X1 Tool ask him to provide you with proper X1 Tool that will work with the firmware he flashes.
Tbh I don't know who this dude is and what's up with all the drama (ok I know some of it, VESC, open source, bankruptcy etc). How do I contact him? Shouldn't he release the firmware/tools because it's GPL'd?
I feel like the community would be better off by hacking and unlocking the original Innotrace, for example by flashing VESC (I did read you mention that someone on the VESC discord managed to do that. I've also seen your thread on the VESC forums. I'm also one of the guys who just recently bought the new VESC 100V 100A controllers, got my PCBs 2 weeks ago :p)
I wish someone with the proper know-how and time would step up and investigate or release their findings. (Obviously using the new VESC controller is the better option, but in the meanwhile...)
He created the firmware for the X1 controller (well, technically he did not created it, he just took the VESC firmware Benjamin created and modified it). Here are the contacts
He should.
He probably even sells same X1 controller for M620, just named it differently so I am sure he has everything you need and probably even more. The controller for M560 on his website is certainly the old INNOTRACE X3 controller, some time ago he posted pictures match the pictures of the INNOTRACE X3 controller.
Dry or Lubricated?
this is our final reply on this matter.
EXFORCE, including Krasnodar, distances itself from Rico, from Innotrace
and from VESC. We have no connection with any of them. Our work has
nothing to do with VESC, and the claims circulating online about
Krasnodar and his work are false. Anyone who knows Krasnodar's work
knows this.
We are happy to help Innotrace customers who act in good faith and do
not let themselves be influenced by false accusations. Those who spread
such claims further without verifying them cannot expect our support.
You are in the second group.
If you need help with a motor that is connected to Innotrace or Rico,
please contact them or the seller of your motor. We want no involvement
in this.
This sounds like a cult or something crazy lol
edit:
I always talked about the Innotrace, but they replied with "we will not provide firmware files, flashing guides or source code. The firmware of our controller is proprietary. It is not open source and not licensed under the GPL.", but talking from EX-FORCE pov, so... confirming they use the same controller? :D
edit:
That's interesting, Krasnodar says he distanced from INNOTRACE but he literally sells the old INNOTRACE controllers just named those differently. I saw those ExForce controllers, he literally just removed the INNOTRACE name from the PCBs and put different name and that's it. I guess for the same reason he removed the pictures of the controllers from the ExForce website when we found it. There are more differences between INNOTRACE X1_V1 and INNOTRACE X1_V2 than between ExForce M620 and INNOTRACE X1, and the ExForce M560 looks just like the INNOTRACE X3.
Also he mentions about misinformation and lack of verification his firmware is VESC based while the verification with the proof his firmware is VESC based is literally here in this thread he also visits meanwhile.
There is a guy popped on the endless sphere forum desperately tried to convince us how Krasnodar updates firmware and supports the INNOTRACE X1 users. It turned out it is not the case at all
I guess you need to ask Krasnodar to provide you with the Rico contacts if he wants you to contact him and ask Rico what is up.
