Can this be used to fine-tune thumb throttle sensitivity? ("start", "end", in millivolts - like on BBSHD) I'm about to do an Innotrace build, and I've tested my friends one - his thumb throttle has wayyyy too much deadzone..I played around a little bit and was finally able to connect via VESC Tool to my Innotrace X1!
If you are planning to build the VESC for Bafang M620 UART controller you better to be sure you are familiar with VESC stuff. There are only a few VESC guys claimed they were able to make that VESC firmware works on that controller and they refuse to share the instructions. But if you will make it works please post the instructions here.Can this be used to fine-tune thumb throttle sensitivity? ("start", "end", in millivolts - like on BBSHD) I'm about to do an Innotrace build, and I've tested my friends one - his thumb throttle has wayyyy too much deadzone..
How about field weakening, I think I heard somewhere that there is very little field weakening applied on the Innotrace. Can it be tweaked further?
edit: from earlier post, the field weakening tab is empty??? XD what is this
I tried it and it did not work from USB, you might need to modify it to make it works from USB.Surely 5V from USB should suffice?
I haven't driven on *my* X1 Innotrace yet, just some test riding on my friends build (which is identical to what I'm going to build...). And I actually kind of disliked it compared to my BBSHD <.<
that's why I have a 15S 50A (~3kW) shunt modded + open soucre firmware'd BBSHDother than a hobby exercise/challenge.
