How would you do it? (Tongue weighing)
I think there are other designs that could work better, but the real problem is the amount of weight that you want to carry. You may have to fabricate something from scratch. This one has a better design and is 16" wide, but only a 60lb capacity.
Not sure i agree it’s a better design ... but it is a different design. The load is carried more vertically, which puts it closer to the bike but also raises the center of gravity. Either could work well, just have to evaluate the pros and cons and make a decision.
You’d take the cosine of the downward force vector by the square root of the tangential diagonal. Not really, just a bunch of random math and engineering terms. I’d probably just load it up and lift it by the tongue as a guess. I carry 40 pound bags of salt to my basement so that’s my baseline.
Thanks Guys
I have the weight end covered, have 800#'s + of bagged shotgun pellets,
all in 25#'s per bag. This will be my test to see the results. for 1 or 2 wheels.
The trailers are somewhere around Ohio??, from the tracking number........
coming from NY..........after 4 days of travel??
Tia
Guys
Here is some more information, per the user manual spec's,
the tongue weight should be between these rates, 6.6 to 17.6 lbs. (maximum trailer load/weight rated at 70#'s)
The trailer weights is 37.5#'s, it is approximately 65+" from hitch point of the rear bike wheel center to center of the trailers rear tire, the trailers load space is approximately 27.5" overall length and 18.5" in width, still looking for info.....
Tracking number still shows it's in Ohio?? Bad weather back there......?
To answer OP, I have a digital bathroom type scale and I can set tere. I use it to estimate bike weights and shipping bikes. First weighing one end then the other and adding them. I would put a sideways milk crate for the correct height on it and make that the new zero. Then I would put my tongue on it. And yes with some weights. The further the weight from the rear wheel and the closer to the bike the more the tongue weight.
The problem with a digital bathroom scale is that a person's pressure keeps changing because he's live weight. When the scale shows a steady weight, that's a digital guess.
I bought this a couple of years ago and never went back to my bathroom scale.
To use it outdoors on an uneven surface, I put down a piece of plywood. I sometimes weigh my loaded trash cart, weighing 47 pounds and rated for 200 pounds of trash. It's much bigger than the scale platform, but the readout can stay out of the way.
To find how much weight a cargo will put on a hitch, you weigh the cargo, then measure where its center of mass is, between the axle and the hitch. If it weighs 100 pounds and it's fastened 40% of the way from the axle to the hitch, it will put 40 pounds on the hitch.
Ped
I can see there is NEVER a dull moment with you around........Lol
SW
The only scale I have access to is a the OLD TIME balance beam scale,
that will go high enough. I'll set it up on the level shop floor to see the results
if and when the trailers get here, last word was they were stuck in OHIO some where,
due to bad weather.
Tia,
Update,
The trailers got here last Monday, the packing boxes look like they were shipped
across the country via pack mule, they were beat to pieces, no damage or missing parts, just some scratches, and I'll add some more......
Guys
If you were figuring out the tongue weight of a Single wheel cargo bike trailer, like this one,
How could you do it?
The only way I can see, is to make a stake to hold the tongue at the approximate height/location as when attached to the bike, set the stake on a scale's center, then add weights inside the trailer, in these 3 locations of front, middle and rear of the frame basket, to read the indicated tongue weight?
The trailer has a weight limit of 100#'s.
This tongue weight question has been asked, but no information can be found, so far.
Your thoughts or suggestions.............
Tia
Your idea of using a scale at the hitch height seems like the most accurate way to do it. It’s definitely worth measuring properly to make sure the handling stays safe.
S777
The medical type swing arm scale is the only one that will go high enough for the testing etc, I am attempting to attach the trailer to the bike, as the OEM skewer did not work, it was too short.
I am making 2 new shock mounting plates, so I can add a second wheel,
just waiting for some parts to get here.
Once everything is here, then I'll do the tongue weight tests to see the difference between a single wheel and dual wheel results.
I am using my bike/trailer to hunt with and pack out game quarters, at 80yrs old,
I am getting to old to pack out game quarters on my back anymore.
My old buddy, "Mouse" RIP, my pack horse finally kicked the bucket after over 20+
of being together hunting/trapping, I am going to be missing him........
Tia
$17. I spent a little more for the 200 kg version. I've got strong eye screws where I might want to hoist something. A piece of rope would do the trick, though. For a light item, I just hang the scale. For a heavy item, I'll hang a hoist and attach the scale.
Well guys, something is not right,
Did the first tongue weight test and here are the results,
Bare trailer tongue weight = 16#'s (Dual rear wheels model)
25# added =TW = 12#'s
50# added =TW = 26#'s
75# added =TW = 59#'s
100# added =TW =65#s
All weights were in the back 1/3 of the trailer bed, (25#'s per bag),
next to the dual rear wheels.
Trailer bed is 27" long x 17" wide, rear axle is 18"from the rear of the bed.
21" from front of the trailer to the attachment buttons on the rear of the bike.
From the attachment buttons to ground level = 13". Overall trailer length = 66"
Per user the user manual spec's,
the tongue weight should be between these rates, 6.6 to 17.6 lbs,
for a maximum trailer load/weight rated at 70#'s.
I think, I'll redo this test again.
Tia
TT
I don't think that will work, if you move the weight forwards
don't you increase the tongue weight?,
and I can't move the weight any farther to the rear......
at 59#'s tongue weight for the 75# test,
I think I am SOL.....
Tia
Move the weight back, mostly, but not completely, behind the wheels. 75 lbs is beyond the capacity of the trailer anyway. Why are you talking about that?
If you move the weight back far enough behind the wheels the tongue weight will become negative. That's almost what you need to do, but not quite. You may not like it, but it's science.
TT
How can I move any weights around?,
When the bare trailer TW is 16#'s, before adding any weight?
It is not possible to move any more weights towards the rear,
as there is no room/area to carrying it.
As I first stated, I believe that I am doing something wrong is the weighing tests, or there is a mistakes in the OEM statement/figures for TW.
The 25#'s weights are bagged lead shot, and I am not going to weigh out 5#'s from each bag to complete this test, so the 75#'s weight listed.
See photo of the dual wheel trailer,
I'll post a photo of my trailer, when I figure out how to post it here,
the above photo is almost the same as my trailer. (Thanks Rusty squirrel)
Tia,
I think the fact that the wheels are set so far back behind the cargo area makes it very hard to move the center of gravity back very far. There are some racks on top of the wheels. Have you tried securing some of the weight there?
,.. There are some racks on top of the wheels. Have you tried securing some of the weight there?
What he said ^^^
No trailers on the road have all the trailers weight on the tongue.
Drape your animal carcass over the rear wheels.
Build a rack over the wheels.
Maybe a bit of trailer behind the wheels?
Less cargo in front of the wheels, and more behind,..
Try to get about ⅔ of the weight directly above the trailers wheels.
