Interesting uses for old bike parts
Jeremy McCreary
Bought it anyway
Carlsbad, CA
Bike upgrades seem to be a way of life on EBR. Done anything interesting with the old parts?
Never got over my childhood love of spinning tops. And now that I make my own, always on the lookout for found objects to turn into working tops. LEGO's a good source for any additional parts needed.
So, when I recently upgraded my Vado SL's stock Tektro disk brakes to these Shimanos, no way the old rotors weren't ending up as tops.
Old 160 mm all-steel rotor. The aerodynamically dirty voids and spokes take their toll on spin time. But this rotor otherwise checks all the boxes for use in a spinning top — perfect rotational symmetry, excellent dynamic balance, high rigidity, high rotational inertia for mass, a center of mass (CM) you can get very low the ground, and secure attachment points for a LEGO adapter.
After testing several adapter designs, settled (for now) on this one, which I also made in black. Adapter details below.
The finished products at rest and at speed. Photos at normal exposures tend to freeze the motion as seen above. In video, you see interesting frame rate and rolling shutter artifacts instead.
In person and in long-exposure photos like this one, the black and yellow adapters produce significantly different visual effects in motion. The black spokes effectively disappear at speed, while the yellow ones turn the silver spokes to gold. Who said alchemy doesn't work?
Closer look at the yellow LEGO adapter. The adapter grips the rotor at the center hole and every other spoke. The only modified LEGO part is the tiny black tip, which I cut from the rounded end of a LEGO antenna. Need a better way to keep the rotor and adapter perfectly coaxial.
These tops work well with finger twirls, but a top this heavy and low-slung can gain a lot of play value with a suitable starter. These all-LEGO starters reduce wobble and increase spin time by delivering a smoother, higher-speed release with better tilt control.
Laser tachometer and black top with timing disk at the base of the stem.
I can spin up these tops to 400 rpm and a 140 sec spin time by hand. From left to right above, the black 2-stage planetary and gray electric starters get them to 800 rpm and 150 sec. The dual-motor wind-up starter gets to 1,000 rpm and 160 sec. And the simple but powerful ribbon-pull starter to 1,200 rpm and 170 sec. Thanks to air resistance, big increases in release speed yield only small gains in spin time.
Top performance
A high-performing finger top has (a) a long spin time for its mass and release speed, and (b) no wobble with a clean release. Spin times are limited mainly by release speed, air resistance, and mass distribution. Tip resistance dominates spin decay only at the lowest speeds. Sound familiar?
The spin times reported above are quite good for a LEGO top with a found rotor. Ditto for the observed wobbles. The black top tends to wobble very slightly at lower spin rates, but some runs don't wobble at all. The yellow top wobbles a bit more.
Hoping to reduce these minor wobbles with further rotor cleaning, LEGO adapter tweaks, and if necessary, some balancing weights.
Wonderfully creative! Skillful, too. Love the bike coming out of the wall.
Your toilet paper (TP) holder could revolutionize TP dispensing. In addition to the old way of grabbing the end and pulling a length of TP off a roll that only spins in place in a wall fixture, you could also grab the end with a fixed hand and move the roll away from it by turning the crank — say, one full revolution. This would measure out a fixed length of TP adjusted by crank length in a time adjusted by cadence.
This changes everything!
@Jeremy McCreary, A couple of years ago I read about someone using angled gyroscopes to reduce the apparent weight of an object on a scale.
This sculpture is in the nearby town of Santa Rosa and was made out of bicycles by a Petaluma artist. I wonder if it will act like a lightning rod.
These belonged to my in-laws. Too nice to throw away, not worth it to restore.
We have a few of those out my way, one yard has 3 in the front yard, like a meetup. Others have rusty old tractors and some rusty old cars and trucks. Me, I just have shrubs, I don't want strangers peering into my yard as they drive past lol
Alice Springs? Darwin?
In person, the black and yellow adapters produce significantly different visual effects in motion. The black spokes effectively disappear at speed, while the yellow ones turn the silver spokes to gold. Who said alchemy doesn't work?
Photos in auto exposure tend to freeze the motion, as in the photo before last. In video, you see various frame rate and rolling shutter artifacts instead.
View attachment 209792View attachment 209791View attachment 209787View attachment 209789
Top performance
Now that is an amazing job you've done.
After the Whizzer top that I had when I was child, I progressed to tops on a string and got pretty good at working a yoyo.
The YoYo Man would come by our school in gr. 7 & 8, and if we could do tricks we would win prizes.
The first prize to win was a couple yoyo strings if you could do a 10 second sleeper.
I didn't make my own, but I just bought myself a Magic YoYo to add to my collection. It glows in the dark !!!
It came with spare "finger spinner" end caps or whatever, so you can do some fancy new types of tricks??
And I bought a pack of spare strings.
The instructions tell you about responsive and non-responsive yoyos and how to get the yoyo to stop sleeping,..
I couldn't get the damn thing to wake up so I think they sent me the professional version designed for a 6 yr old instead of the beginner version for a 3 yr old.
(It's a children's toy for 3-6 yr olds.
Children under three might try to eat the yoyo.)
So I had to do some research,..
So it looks like I need to buy the thinner non-U shaped bearing if I want to have a normal yoyo that will wake the hell up??
I need the thinner bearing, and a shorter axle, and the special tool to remove the axle.
Due to measurement allowed error, the beginner bearing is somewhere between 0.17cm and 6.17cm thick.
The return mechanism is pretty cool.
It's a blue rubber ring on both halves of the yoyo that rubs on the string to get it to wind up, but the expert U-shaped bearing keeps the string away from the rubber ring.
So instead of spending almost $20 to get the responsive bearing and tool kit, I decided to try to figure out how to get the string to wind up like any 6 yr old knows how to do.
I had to learn a bind my unresponsive yoyo,..
It Worked !!
I figured it out, and I learned a new trick.
I think I'll bring my yoyo along with me on my ebike rides to give my hands something to do instead of smoking cigarettes. 😁
View attachment 209931View attachment 209932View attachment 209933
It Worked !!
Hey, that's an idea for a couple of old disk brake rotors or chainrings. Make a giant YoYo out of them!
Or even better,..
Make a Battling Tops board game like I had when I was a kid,...
And to make it COOL, you'd need razor sharpened edges on the rotors, or maybe serrations?
What ever kills your opponents top.
Players will have to wear protective equipment to play the game.
It needs to be dangerous to be fun, like the exploding clackers from that era. 😁
