kevinmccune
- USA
who put "fun" in funeral?
The mortuary owners.who put "fun" in funeral?
Isn't that an Irish thing?who put "fun" in funeral?
could be.i know the "wake" is.Isn't that an Irish thing?
One thing I won't certainly understand is a guy riding a road bike in regular clothes, helmetless or in a baseball hat.Clearly a lot he doesn't understand about cycling — especially the reality of air resistance and the value of functional clothing for some kinds of riding. But he does point out a reason to ride in lycra I hadn't thought of: If you ride in regular clothes, people might think you had a DUI.
Amazing!This French guy sings to animals. He has quite a few compilations. It is so interesting how the animals react:
I so love it. I have been feeding crows I see on rides. Also putting some cat food on a 4x4 post. Now they recognize me. One placed a chromed Nexus/Alfine acorn nut on that post as a gift. How could they know, a bike part? Someone said that an analysis of calls repeated a unique pattern whenever one regular bike commuter passed. They had named him. The ring tailed lemurs are the best. I get six caws.This French guy sings to animals. He has quite a few compilations. It is so interesting how the animals react:
What is scary to me is that they need to solder the copper pipes inside your walls with a torch. What could go wrong?Many holes in the walls and ceilings
the good news is, take a grinder to said pipes, turn the water back on, and problem solved!What is scary to me is that they need to solder the copper pipes inside your walls with a torch. What could go wrong?
They may solder new pipes but they may use Sharkbite connectors instead, and especially for repairs. If you don't know about them check them out. They can be a lifesaver.What is scary to me is that they need to solder the copper pipes inside your walls with a torch. What could go wrong?
I looked it up. When I did it I made a heat shield from double walled (with an air gap) large coffee cans. It was to install a valve for an icemaker line. I also cut a gap in the top and bottom so it fit around the pipe.Sharkbite connectors
You haven't tried them. I've had some in place for many years. I can solder too, nothing against solder, but SharkBite fittings are fantastic.Solder is for ever, o rings are tick tocking to failure
