This is brilliantthank you!
I would like to do this if I can find this product![]()
The easy way is to just use paraffin wax. I use a base of soy wax with some paraffin and a dash of Muc-Off dry lube. Straight soy is not corrosion resistant enough on its own. Paraffin is inexpensive.if I can find this product![]()
That said, I don't expect it to last a year as others suggest...
What some are doing and I plan to try at the next chain change is pure paraffin and some dry Teflon powder.
Ratio 50:1 respectively.
Your links didn't work for me in Canada, so I just searched Amazon.ca and bought some wax and Teflon powder.
My original bike chain wax has Molybdenum Disulfide in it as well, but it's $67 now and 2 ounces of Molybdenum Disulfide powder is $37, so I just bought the wax and Teflon.
I see what you did thereStill no "wear" near 0.75 stretch.
The WD 40 dry lube would probably work to keep dust from accumulating on most bike surfaces but IMO, it won't provide enough lubrication for the chain.So; apart from the hot wax solution (which probably lasts longer)… had anybody here tried the WD40 Specialist Dry Lube - sprayed onto a clean chain?
The so called theory about this option is that:
• Dust won’t stick to your chain, and will even just blow off.
• And it will entirely rinse off with a hosepipe leaving a clean/non greasy chain to start over - which is why it’s unfavourable in wet climates.
Your thoughts?
