Ah thanks Stefan, informative as always.
Is 35/35 the most quiet setting? or is there a tweak here I can do?
I find eco louder then Sport or Turbo - on hills anyway. I put it down to the restricted (and small) motor having to work harder so it has a higher pitch, sounding quite shrill. When the road rises further and I hit Sport the note is lower.
I've tried tons of settings. For me... I use Eco 35/35 when I'm trying to conserve power and am going on a longer ride where I'm not sure if I'll have enough battery. I really want to use sport as the mode I'm using when I'm just riding and not thinking about things and I know I have plenty of battery for the ride. I've tried Sport at 50/50, 55/55, 60/60, and 65/65. I've also tried 30/100, 50/100, 55/100, 60/100, 65/100. Using the /100 settings feels to me like I'm pushing myself but also getting assistance when I need it up hills. 55/55 and others like this, helps, but I'm not getting enough assistance on the hills. Sometimes on steeper hills I want to switch to Turbo.
30/100 doesn't really help that much on the hills, because I'm not able to output enough power to have the motor help me as much. I might as well be on regular ECO with a little more help.
50-65/100 seems to be the most comfortable. I can go fast 15mph+ average. I get a good heart rate. I don't feel like I'm killing myself on hills. Right now I have it set at 60/100, but might go down to 50 or 55. When I tried it last time at those rates, I felt like I was tiring out more quickly on the hills.
@mogulman: If I may suggest something, please do not try anything above 60% as the basic Assist (Ease) for long rides. Above, the battery goes off the cliff. I'd say, 50 or 55% are safe numbers.
Interesting. Why would there be such a strong rise in battery drain rate above ease E = 60? Motor power (Pm) is either linear or flat in E in steady riding, and the drain rate is roughly proportional to (Pm / e), where e is the motor's electromechanical efficiency.
Hopefully, the efficiency doesn't fall off a cliff at E > 60. And if it does, how come?
Jeremy, I don't know why and even do not try to guess. What I say is experience based. There was a time I actively measured the Vado SL range at different assistance levels, and it was usually at E=M. (Bear in mind I own as many as 4 Range Extenders and never hesitate to use them, haha!) I even made some graphs that I posted on this forum but we won't find them.
My basic assistance for gravel group rides used to be 60/60. It was good to ride together with weaker, especially tired riders. Riding with average guys and girls required 80/80 (and the derestricted speed). 100/100 was impractical as the batteries were drained too fast and it was still too weak assistance to keep up with the "horses" on asphalt. (I could keep up with the "horses" on gravel riding my Vado 6.0 at 60/60, equivalent to SL 120%).
The charts showed Vado SL was economical up to 60/60%. Above that, there was a curve of range decrease and then the curve became very steep. It might have something to do with the air drag?!
I went on a short ride today and my spoke protector broke.
A few rides ago, I noticed one of the plastic clips broke off and it was not centered. I re-centered it and figured it would hold on, but today it completely broke and was flopping around on the rear hub like a dying fish. It freaked me out at first since it sounded like a bunch of broken spokes.
I stopped on the side of the trail and removed it (by breaking it open on one side and sliding it off the hub).
Is it worth replacing this thing, or should I just forget it?
I had one on my old bike do the same thing, although it lasted 20 years before it finally broke.
Never had any issues with not having it on there, but that old bike didn't have disc brakes.
I don't want to get the brakes contaminated. I don't think the chain will fall off that top gear either since I never shift into that gear.
@Cycologist - If you keep the low gear derailleur stop screw adjusted properly to prevent the chain from shifting past the largest cassette cog you will not need what some refer to as a “dork disc”. If you want to be safe and prevent problems from the chain getting jammed between the cassette and hub/spokes you can replace the plastic disc, but it can fail as you found out.
That's what I figured. Thanks.
This week is shaping up to be bad luck for biking, at least for me.
Today I was getting the bike ready for another ride when I noticed the rear tire was completely flat.
This is the original Specialized tire which is supposed to have "Black Belt Puncture Protection".
After examining the tire, I noticed a tiny rock stuck in the center tread and it went in pretty deep. This was probably the culprit.
I took the tube off the wheel and tried to find the hole, but I couldn't. I had to dunk the tube in a bucket of water before I could find the exact location of the hole.
It was so tiny that I really couldn't even see it until I brought the tube outside in direct sunlight, then I finally saw it.
Patched it up and did my ride, although I lost about 45 min, so I had to cut it short.
I have a couple of TPU spares, but I want to save those for emergencies. I carry one with me in my bike bag.
Bipolar SL tuning
My riding on the SL is becoming increasingly bipolar all on its own. That means splitting much of my saddle time between OFF and SPORT.
If my subconscious has a rationale for this trend, I haven't been informed. But really enjoying the result: One minute, the serenity of OFF without motor noise. The next, the thrill of substantial assist with carrot effect and the speed that brings. Totally on whim. Good workout either way.
Q. Does anyone else ride an SL like this??
Going with the flow, I'm now testing this equally bipolar Universal tuning. Hereafter, E will stand for the graph's ease setting, and M for the motor power setting. In the Specialized app, E and M can change only in increments of 5.
For comparison, the factory Universal tuning I've been using since purchase. These factory modes are evenly spaced in a proportional sense, and probably not by accident.
Spreadsheet analysis: Upper teal panel holds the relevant SL 1 motor parameters. The middle blue panel calculates what an evenly spaced SPORT would look like given the ECO and TURBO settings I chose to test.
Symbols: Pm = mechanical motor power at the crank, Pr = rider power, Prs = saturation Pr, where Pm hits the cap set by M. Pedaling above Prs will get you that much more power at the crank but no more help from the motor.
The lower coral panel shows the closest approximation I could program with the app. Looks very linear but still pretty close to proportionally even spacing.
Really liking the new 40/60 ECO. Significantly zippier than the factory 35/35 — especially above the previous Prs of 133W. Quieter, too. At current fitness, no problem sustaining the new Prs of 200W.
At 60/80, SPORT now summons up to 33% more Pm than the factory 60/60 at Pr > 133W. Powerful carrot effect trigger.
Lowered the E in TURBO from 100 to 80 to make this mode more useful in less extreme settings, but kept the M =100 to retain access to peak Pm at Prs = 167W and above.
Early days still, but this new bipolar tuning feels very promising for my new bipolar riding style. Battery range will surely go down, but with the OFF segments, probably not enough to impact local rides.
Though my retired brain no longer wishes to follow the math, your discussion, settings and experiences are similar to mine. I don’t do zero assist very often anymore, but my assist levels are similar to yours. 35/55, 60/80 and 100/100. I only use turbo topping a steep or longer climb. I also use the settings Stephan touts - 35/100, 55/100, 100/100 (from memory). He and I discussed this idea a few years ago. The settings fit his riding needs more than they do mine.
The ability to customize our bike’s performance to match our human capabilities is one of the best features of those bikes that offer the capability.
The results are in: 40/60, 60/80, 80/100 is zippy fun but eats too much battery for routine use — especially on bigger rides. For example, burned 71% on a recent 30-miler with 3,000 ft of gain done almost entirely in 40/60.
Apparently, if I give myself access to more motor power by raising the M in E/M, the carrot effect sucks me into using it. Result: More fun, faster rides, and paradoxically, better workouts, but at a price — less range and shorter battery service life over time.
Now testing a more conservative 35/50, 55/70, 80/100. These modes saturate (hit the motor power cap imposed by M) at rider powers of 190W, 170W, and 167W, resp.
It’s nice to see you’re taking the 1.8 (or so) rider multiplication factor into consideration in your examples showing the rider power that hits the motor cap. You may have seen the specialized app reports motor power peaking out around 308 Watts, which is the max electrical input they allow in hopes of getting the 240 mechanical W output from the motor. That’s where the “80% motor efficiency” seems to come from. I think that would require ideal conditions, considering the efficiency loss in the battery chemical to electrical conversion, then the motor’s electrical to mechanical, and finally the drivetrain losses.
I remember reading a user’s post on another site where he put his creo on a smart trainer and used power pedals to get accurate input and output W measurements. He wasn’t able to quite reach 240 watts at the rear wheel. I think it was 10-20 watts or so short of that. Thanks for posting your experiences and findings!
Thanks! I'd love to see some of the sources you mentioned. Made my model of the Specialized power-sensing mid-drive PAS by taking their own documentation at face value. And that seems to have produced at least ballpark results for steady-state riding.
But c'mon, how could the SL 1.1 motor have the same 240W peak and continuous mechanical power rating?
An how does that claimed 80% electromechanical efficiency not vary with motor shaft speed and hence cadence — even in the recommended 75+ rpm range? Must be superimposed controller effects at work here, because brushless DC motors just don't work like that on their own. (Play around with Grin's online motor simulator to see what I mean.)
Hard to know the real drivetrain efficiency of an SL or Creo. The 98% used in my model is an educated guess based on many sources, but efficiency on the smallest cassette sprockets could be lower.
If the motor were really delivering 240W at the crank, you should be seeing 235W at the rear wheel at 98%. That 5W drivetrain loss is a lot smaller than the 10-20W reported.
Scraping front brake on my SL 1 had to be bled and repadded after some very heavy use in the last few days. Closing in on 1 year and 3,000 mi in pretty hilly terrain. Same happened to the much more used rear brake 5-6 months ago.
Q1. Is this normal?
Q2. Should I be pushing for more than bleeding and pad replacement while I'm still under warranty?
I trust my authorized Specialized mechanic, who routinely works on bikes costing 3 times as much — think Colnago, Pinarello, Factor as well as Specialized. He says it's normal, but it never hurts to check.
Q3. I tend to keep a pretty firm grip on one or both brakes at stops. Just a habit. Am I contributing to the problem?
Thanks!
Q1. Is this normal?
Thanks!
I've only replaced pads, never had to bleed in the (coming up to) 5 years. But the pads wear out frequently on the steep hills. At first I was surprised at how quickly this occurred, but my local bike mechanic said that around here, everyone is constantly replacing brake pads. So that reassured me. It's just a regular part of the bike's upkeep now. Must ask him about bleeding, if & when I should do this!
Jeremy,
Bleeding the hydraulic lines in the brake system you have is a rare thing (I'm with Rás on that). The brake pads do wear in hilly terrain, no doubt. Not sure what your brake pads are but I would go with semi-metallic ones were I you. The only con of semi-metallic pads they can be squeaky (especially after it has rained; but "Seems it never rains in southern California") :) As for me and the flatland I ride, the organic pads are OK and they last forever (2,460 miles and counting...)
I think brake pad replacement and hydraulic line bleeding is not included in the warranty (same as oil change or replacement of brake pads on a car are not on the warranty). You may have a special service arrangement with your LBS though.
The best way to brake is to gradually increase the finger tension on the brake levers as you are stopping. To control the speed on a descent please brake intermittently (brake, release, brake...) That allows the brakes cool down (or at least not get hot) during the operation.
Jeremy,
Thanks! The bleeding is the part that worries me. Will ask the mechanic what pads he prefers for my bike. Certain they're quality pads.
Yes, doesn't rain often here. Mainly a winter phenomenon, but didn't get much last winter, either.
Yes, bleeding and pads not included in the warranty. But if something else should be replaced given the frequency of the bleeds I've needed, that would likely be under warranty. That was Q2.
Thanks, already doing all that. Q3 was about what I'm doing with the levers once stopped.
