tomjasz
- USA
- City
- Minnesnowta
You know, your battery charger should just NEVER arc when you are connecting a battery to it. The cost of the parts to prevent that from happening in a battery charger is less than $1.
Oh man, early adopter here too. I’d forgotten the punishing pricing. And how much of a market leader that product was. A couple of decades of innovation and WOW! Leaps and bounds.I had the first portable CD player available. A Sony Discman that I bought ~1981.
It was a $500 Walkman, and the proprietary 9 volt 1 amp power supply for it was $50.
More than a few people didn't want to spend the $50 for the Sony power supply, so they bought a $10 off the shelf power supply.
When they plugged in that power supply, they wrecked their $500 Walkman.
Sony in their brilliant marketing plan, decided to reverse the polarity of the 9v barrel plug on the power supply to positive ground.
A simple 10 cent diode would protect the CD player from reverse polarity, but Sony didn't want to do that.
They wanted to sell you another CD player.![]()
Ah, youth. It didn't matter if your car broke down, as long as you had good tunes--all was well.I delivered pizza in a $500 car with $1500 worth of stereo in it.
CORRECTION: Boy, did I misremember that video! At the very end, he says to make the wall connection first. Nothing about breaking connections.
My advice would be to make the 110v connection AFTER making the battery side connection when hooking up the charger, and removing the 110v before disconnecting the battery.
WHY? It's about capacitors and the HUGE amount of voltage that may be stored up in them, especially in the older rigs. Once you experience the big lightning bolt and associated POW that may be the result of incorrect connection order, I can pretty much assure you, that you'll NEVER forget that lesson.
I don't care what the instructions say. Capacitors are nothing to mess with......
It was a different than blowing a capacitor. I know what that sounds like.
The Zen ebikes guy recently posted a very extensive and thoroughly researched "white paper" video on the care and feeding of lithium ion ebike batteries. He has a degree in a related engineering field.
He said to make and break the charging connection at the battery with power to the charger off.
How does an E-bike charger work? [ Video with Animation]
The safety of an E-bike battery is intricately tied to the quality of the charger used. With millions of E-bike chargers on the road, it is important to understand how E-bike chargers work. We put together a video to explain the mechanism like CC-CV, what is a smart charger and how to select the...electricbikereview.com
A great question. I contacted Ride1Up about the BMS. I specifically asked what its rating was. I got no answer because, I believe, A) they don’t know or B) they know I’m looking to modify my bike in some way. Either way, I got no answer. This leads me to believe that most sellers are selling the bike to you, then it’s all up to you for any needs.Ravi
How is the average rider/bike owner know which is what type of BMS/chargers are?
