Spooked by recent recalls - Are these battery charging cabinets worth the investment?
The FCC have just banned all none US fully manufactured routers.
I wonder how long before it spreads to other electronics and software.
Loads of chinese bms have bluetooth and bespoke apps.
I was here for the birth of the netz and maybe here for its demise
Quality hardware, understanding battery safety basics and common sense are key... but we also need to put things into perspective.
Based on data from the National Fire Protection Association (NFPA) and FEMA, the top 10 most common causes of house fires are:
1.Cooking: Unattended frying, grilling, or boiling; grease buildup; and flammable items (like towels) too close to the heat.
2.Heating Equipment: Second leading cause overall. Risks include space heaters placed too close to curtains or furniture, unmaintained furnaces, and wood-burning stoves.
3.Electrical Systems & Malfunctions: Faulty wiring (especially in older homes), overloaded power strips, and loose outlets.
4.Careless Smoking: Discarding cigarettes improperly or smoking in bed; this is a leading cause of fire-related deaths.
5.Candles: Leaving an open flame unattended or placing it near flammable materials like paper or fabric.
6.Intentional (Arson): Fires set deliberately, which account for about 4% of incidents.
7.Children Playing with Fire: Curiosity with matches, lighters, or fireworks.
8.Appliances (specifically Clothes Dryers): Accumulation of lint in dryer vents is the primary trigger for these fires.
8.Open Flames (Other): This includes fireplaces without screens, outdoor grills used too close to the structure, and fire pits.
10. Flammable Liquids: Improper storage of gasoline, kerosene, or cleaning solvents near heat sources.
I'm not suggesting that you approach this with your head in the sand but lithium batteries don't even make the list. I haven't stopped cooking or heating my home or using my fireplace, the top causes... But I do implement the necessary precautions without hysteria
That's a fair comparison, and the data doesn't lie. But context matters too. Living in a small apartment, the 'risk profile' feels different than in a large house with a detached garage.
If my stove catches fire, I'm usually right there to handle it. But if a battery goes into thermal runaway while I'm asleep in the next room, the speed and toxicity of that fire in a small space is terrifying.
I agree we shouldn't live in fear, but for apartment dwellers, that specific low-probability event could be catastrophic. That's why I'm looking at these lithium-ion battery charging cabinets—not out of hysteria, but as an insurance policy for a worst-case scenario.
For those living in confined spaces, with no other alternatives, these charging cabinets might be a viable option. However, instead of spending $600 on a cabinet, another idea would be to put that money toward a quality UL approved battery.
That sheds a little more light on your particular situation. You also need to consider other tenants in your situation so perhaps taking extra measures may be prudent.
I say do whatever will give you peace of mind.
I think that those cabinets would not be able to contain the smoke unless they were vented to the outside. The first and best investment would be as @6zfshdb said and buy a quality battery built with name brand cells and never charge it unattended or while you are sleeping. Most of the time, but not always, they catch fire when they are being charged.
Your last sentence, if correct, tells me unauthorized chargers are involved. Trying to fast charge?
??? I haven't personally experienced an ebike battery fire. I use a Grin Satiator. My batteries are from Grin and EM3EV. Both companies sell the Grin Satiator for charging their batteries...
I didn't mean you. I'm curious in general. If most ebike fires occur during charging is it because unauthorized chargers meant to quickly charge a battery are the main reason.
Battery failures are usually a result of manufacturing defects, physical damage, or abuse. If you have a quality battery, it should have a BMS that prevents charging the battery at too high a current. It will shutdown the battery properly at the low voltage cutoff. It won't discharge at too high a current. And the best ones will have bluetooth to allow you to monitor the battery and cell balance.
If you have a cheap battery using generic no-name cells, you can be sure that corners were cut during the manufacturing of the cells and the safety features of the BMS. There is a higher risk of internal shorting in the battery and of overcharging or charging at too high a rate with a cheap battery. Failures usually happen during charging, because the internal temperature of the battery is higher during charging than when the battery is not being used.
I have two batteries for my Rad Rover that are 5 and 6 years old. They've never even gotten warm when charging. The charger gets a little warm to the touch but never the batteries.
Fair point. But let's be real, a lot of us are stuck with the batteries we already have. I’m actually pretty skeptical of my own setup—I hit up support and they claimed my battery is UL2849. Does that sound legit to you guys, or is that just a red flag for a 'fake' UL cert?
That’s why I’m going with a cabinet. It’s a cheaper insurance policy compared to dropping $1.5k+ on a new UL approved bike with a guaranteed legit battery. Ideally, I’d have both, but looking at my bank account, the cabinet is the smart move right now. Still saving up for a 'real deal' UL bike with name-brand cells down the road, though! Lol.
They really don't make 'em like they used to!
Are you, though? Some bikes like Specialized use a propietary battery, but those are almost always quality batteries. Many cheap bikes use generic batteries that can be replaced. A good battery from EM3EV will set you back the same or less than that cabinet.
Ask them for their UL Certificate #
https://www.ul.com/cere-search-certificates
Just understand that a UL certificate is a safety standard, not a quality standard... and they don't necessarily walk hand in hand. I've seen lots of poor quality electrical fixture, devices with a UL label.
In this case.... it's still a meaningful asset.
edit: If you want to continue with your battery there are some basic things you can easily do. Always charge when you're around and awake. Charge at a low current, 2a is ideal. Don't charge to 100% when a full battery won't be needed. Set it up with a timer to always end charging automatically.
In addition to cheap cells some of the deficiencies of inexpensive batteries is in the implementation of weak safety features.. These suggestions add some back.
Keep in mind, a misused UL approved battery can be just as dangerous as a cheap Chinese knockoff. Dropping, consistent overcharging, charging at a high rate or when too hot or cold can make ANY lithium battery a disaster waiting to happen.
Something else to think about. Cheap batteries usually come with cheap chargers. Some can overheat and also start a fire. The cooling fan can fail on some models and without a thermal cutoff, can be just as dangerous as the battery.
Isn't a BMS supposed to prevent overcharging? Wouldn't a UL approved BMS do it well?
I once dropped my Radrunner battery 9" onto concrete. I'd been concerned about the possibility since it was new. It was hard to keep hold of that battery, especially during removal. OTOH, the plastic panel on my Aventon battery makes grasping it foolproof.
You might be able to look them up in the UL database: https://productiq.ulprospector.com/en/search
