You probably mention the Creo 1 Evo. Creo 2 is as ideal gravel e-bike as an e-bike can ever be. Yes, a 320 Wh battery but an unlimited number of Range Extenders. (You can decide how many 1-kg REs you are taking on the trip).
Thanks for assuming I mispoke, but I
was talking about the Creo 2. The Creo 2 has a 71° head angle, vs 67° on the Tributary (4° is a
huge difference). The Creo 2 has a 435mm chainstay vs 445mm on the Tributary. Creo 2 has a 1022mm wheelbase (small) vs the Tributarys 1094mm. BB height is over an inch higher on the Trib (270mm vs 303mm). The Trib geometry says they started with the Cutthroat, which is a
really good endurance off road bike.
In addition, the Creo 2 comes with roadie bars. I mean, the small comes with goddamn 380mm road drops. The Trib comes with Salsa Cowchippers (which are great shallow drop gravel bars) and the small starts at 440mm wide which are muuuuuch better suited for gravel.
The Creo 2 actually has geometry
extremely similar to my non-electric gravel bike (Motobecane Century Ti) which I'm obviously very familiar with. 71.5°, 430mm, 1016.5mm, 274mm. Its endurance road geometry, though obviously it works ok on gravel.
The point isn't that one is better than the other, but they are obviously designed from the ground up for very different purposes. And I'm genuinely confused why you feel the need to come into an unrelated thread and crap on a bike you clearly know little about to shill for a bike that is not even a direct competitor. Does
Specialized, like, pay you for this service?
The only ebike on the market I'm familiar with that actually competes in this space is the Niner RLT e9.
I had a pool of 960 Wh (the main battery and four Range Extenders: 4 kg extra to be carried). Plus two chargers, so I was rather on a heavy side. Yes, I had to do some recharge at an agrotourism farm.
I'm not sure "supplementing the small main battery with $2000 worth of range extenders" means that the Creo is a long distance beast the way you seem to think it does. Sure, you can do that, but it doesn't mean thats not a kludge.
Certainly, certainly. I only would need to hear from any early adopter who has ridden a Salsa for 100 miles yet
And has carried the e-bike over a creek or a big fallen tree
Or, was carrying their e-bike up a sandy hill (where you could not use Walk Assist. (You are right: the Bosch Salsa is an XC e-bike with drop bars.)
The fact Salsa had invented modern gravel cycling does not mean the brand is good at e-bikes.
LOL. "Salsa literally wrote the bike on gravel and bikepacking over the last 15 years, but it remains to be seen if they can handle buying motors from Bosch and attaching them to their bikes".
