Please kindly tell me how to disconnect the wires. My intention is to remove the rear fender & rack and use a rechargeable tail-light for less weight and a more sporty e-bike!Great question. I disconnected and removed until I reinstall the fenders and rack.
Stefan: I did a clean wire cut out side of the bottom frame. This week I need to complete the job with a small wire connector. Deciding which style to use. Upon my completion, I will post some pics.Please kindly tell me how to disconnect the wires. My intention is to remove the rear fender & rack and use a rechargeable tail-light for less weight and a more sporty e-bike!
I might want to drop the motor and remove the connector from its socket. Not an action for faint-heartedStefan: I did a clean wire cut out side of the bottom frame. This week I need to complete the job with a small wire connector. Deciding which style to use. Upon my completion, I will post some pics.
I thought debated about a motor drop. Not sure how difficult that process would be. With that being said, I want to use a small two wire connector in case I reinstall the fender and rack. Also as you mentioned, rerouting could be an issue. I currently use a seat post mounted reachable red lamp. Love the SL for gravel with Pathfinder Pro's.I might want to drop the motor and remove the connector from its socket. Not an action for faint-heartedWill ask my brother to do the motor-drop for me.
I cannot undertstand how it is done for the non-EQ version! I reckon that version uses a SWAT compatible saddle mount and a dedicated tail-light. No idea what it could be... I cannot, however, go that way as the Redshift ShockStop seat-post prevents routing the wire inside it.
Anyway, after disconnecting the tail-light, I intend to remove the rear fender and the rack. I would be using a Knog Road Blinder rechargeable tail-light mounted on the seat-post that is currently gathering the dustFor the time being, I'm keeping the headlight. However, it will become temporarily disconnected, too, when I'm riding my gravel races (as the lighting consumes too much battery charge when the latter is critical).
Easy to do since the magnet is integrated with the lockring.Remember to move the magnet to the rear wheel when you have installed the brake rotor!
Not enough clearance to get a cassette tool in there to tighten the lockring. I have a "solution" and should have it resolved by later today...Cannot see anything wrong...
there is plug thta the tail light wire plugs in to by the motor, my LBS told me you can get to it by removing just the cover, i don't think you need to drop the motor but please let me konw I would appreitated it. and if possiable post some pix please. i didnot want to cut wires.I might want to drop the motor and remove the connector from its socket. Not an action for faint-heartedWill ask my brother to do the motor-drop for me.
I riding with the B-17 on my SL. Really like it.One good candidate turns out to be the Brooks B-17 that I used 20 years ago on my old Sequoia touring bike.
Great info on the Long Wire! I'm interested to see which tyre you choose. I'm wanting to go wider than my 38's.Next Steps To Convert My Vado SL 4 EQ Into A Sporty Gravel Bike
I was getting unexplained inner tube punctures in the front wheel since the last gravel group ride; these were tiny holes with the deflation taking several hours! That made me really irritated. Solved the issue by filling the inner tube with a lot of sealant, spreading the liquid by often spinning the wheel, giving it time to seal the puncture, and reinflating. The issue seems to be temporarily solved but the whole situation made me want to do many modifications so I could enjoy a sporty gravel e-bike for this year's races.
First of all, I made a booking at an LBS in the neighbourhood for the tubeless conversion for April 15th! I need more aggresive gravel tyres in size 42-622 (700x42), so had to eventually remove the rear fender (including a damaged tail-light) and the rear-rack. (The front has its fender removed for several years now).
@CodyDog: you will laugh! I started with dropping the SL motor to see how the tail-light wire was routedIt has turned out the wire is very long, and it travels above the motor and through the bottom tube to reach the TCU! So I did exactly what you did
Cut the wire at the motor and insulated the end. I actually didn't need to drop the motor but at least learned doing it myself!
Removed the rear wheel to remove the fender and rear rack. One of the screws stuck. I got furious and now the fender including the damaged tail-light is in a bin. (Now, a Knog Road Blinder R70 is on the seat post as the tail-light).
Dropping the motor required removing the chainring. Having had such an opportunity made me swap the 42T chainring for a 36T one. That required shortening the chain. Now, I have a 11-51T 11-speed cassette, a 36T chainring, and the chain length is 118 links.
The next step will be temporarily installing the set of SKS Speedrocket mudguards for the wet season, and eventually the tubeless conversion. Does anybody have experience with Specialized Tracer Pro or Rhombus Pro tyres? I need more aggresive tyres for my gravel rides but would love having them rotating fast on asphalt! @Nubnub? @AvalancheRun?
No pictures until all the work has been finished and my Fearless gets a good washing!Now, I am almost ready for my races!
I have been stuck with the tyre size by the fender for a long time. I also needed to swap the tyres between seasons (now, I will use my Vado 6.0 as the heavy duty all season e-bike). The latter was preventing me from the tubeless conversion.Great info on the Long Wire! I'm interested to see which tyre you choose. I'm wanting to go wider than my 38's.
Thanks. Look nice on that yellow bike! You've convinced me to give it a go, although even though it and the Anatomica are both leather, they're quite different in design and feel. I might end up with the Anatomica in the end, but I have nothing to lose by trying my old trusty touring saddle!I riding with the B-17 on my SL. Really like it.
I had a Anatomica in the past but sold it with a bike. I did like a lot and it is different from the B-17. The problem is trying out the better seats as an experiment can get expensive.Thanks. Look nice on that yellow bike! You've convinced me to give it a go, although even though it and the Anatomica are both leather, they're quite different in design and feel. I might end up with the Anatomica in the end, but I have nothing to lose by trying my old trusty touring saddle!
No complaints with the tracers. They work great on and off road. I’m not blown away by them, but also see no reason to change.Next Steps To Convert My Vado SL 4 EQ Into A Sporty Gravel Bike
