lewes5
If your crotch is being crushed when you are standing flat footed over the bike's top tube, then your bike's frame is too large for you. You should go to a smaller frame. You should have 2 inches of clearance between the top tube and your crotch. This is one of the standard measures for sizing a regular road bike.
But I think the rule holds true for an ebike as well. )
Obviously, with a correctly sized frame, swinging a leg over is not as difficult. However, if, as others have mentioned, you have panniers on the bike, swinging a leg over is more difficult and a step through makes far more sense.
Exercise helps. I had my right knee replaced about 18 months ago. Several of the exercises I had to do during PT worked the leg. Holding on to a bar, I kicked out, kicked back and kicked out to the side - three minutes for each. When I got back on the bike several weeks later, I found I could far more easily swing my leg over, mounting and dismounting the bike. And I am 76, short and stocky with stubby legs. I am currently riding a Specialized Vado, non step through. But I suspect my next email will be a step through.
