Crosscore rc rear rim/ speedometer
SweetTrade324
Hi I bought a used crosscore rc. Got it for what I thought was a steal but it's cost me a arm and a leg. Long story short I had to replace the rear rim and went with a aftermarket suggested by my bike shop. Of course we didn't think about the built in magnet for speedometer. Now I have no speed reading which is fine but the motor kicks off at 16mph now. Any ideas? Closest dealer is 3 hours too BTW.
Sorry IDK, but the new tires look nice.
Maybe the post about civante speed sensor would be helpful.
How did you resolve your issue? How can the motor turn off at 16 mph if it can't detect your speed?
I just purchased a new rear wheel for my Yamaha CrossCore. I fit the Yamaha magnet assembly in the disc centerlock area and all seemed fine. BUT a few seconds into the test ride the display turns red and states "CHK MAGNET". This is frustrating. I am seriously considering moving the frame-mounted pickup forward and placing a magnet either on a spoke or on the crank arm. I don't care about having the correct speed.
I used my lathe to modify the hub on a DT Swiss hub. The groove width and location are exactly the same as the Yamaha, but I didn’t go as deep because the tabs that fit into the groove do not require it to be that deep. I used an “emergency collet” to hold the flange without damaging it, but a simple machined arbor would work fine. It is a quick and easy job, but it does require a lathe, groove tool and a good way to hold the part without damaging it. Pretty much any machine shop could do the job easily, (or any friend with a decent lathe).
The DT Swiss and Yamaha parts easily, (or any friend with a decent lathe).
