rob feature
 - USA
- City
 - Greenwood Village, Colorado
Two other people I met with same bike have the same issue.
Are you sure original components are fine ?
Thanks
Yeah, the Alivio stuff is great. It's not the latest tech with 12 speeds, a clutch, and extra do-dads, but it does what it does very well. Any setup will shift poorly if it's not properly set-up (or damaged), and whoever assembles these bikes is not very good at it. Has it been tuned by an experienced wrench? There are tools that can diagnose this when in the hands of a competent mechanic. I've put 3k miles on one in a year and can't say enough good things about it. Actually it's one of the best-shifting drivetrains I've ever used.
The chains that come on these do wear out too quickly - they really need ebike chains - especially if you're mostly using Turbo mode. I think I got almost 800 miles out of my original chain before it failed the go/no go test and that's mostly in eco mode. Over 2k on a new ebike chain and still going strong.
Misalignment of the rear hub can also affect shifting. Those 2 smallest cogs are at the extreme end of the range & will be a little more sensitive to small variations than gears closer to a straight chainline. Spending a lot of time down there at low cadence may be doing bad things to the motor too.
