I have a Volt Biker Mariner from 2018 that stopped functioning -- no life at the controls.
I removed the battery and tested the resistance across the battery terminals on the bike side (not on the battery side) and discovered a dead short -- 0 ohms.
I opened the controller compartment and do not see any visible damage.
I one by one disconnected the wires from the controller to see if the short would open.
Nothing made any change to the resistance except for the blue wire (one of three: Yellow, Green and Blue) from the controller to the motor. When I disconnected the blue wire, the resistance went up quite a bit.
I then tested the resistance between the yellow/green, yellow/blue, and green/blue wires coming from the motor and discovered they all have a resistance of 0 ohms. Is that normal?
I don't know what to do next to determine if the fault is with the controller, the motor, or one of the connected devices (on/off switch, display, throttle, motion sensor, etc.).
Here are pictures.
Thank you!
Here are pictures.
Thank you!
