Gionnirocket
Well-Known Unidentified Member
- USA
- City
- Y. O.
If you have the stock thumb throttle, most are using 1.1(11) and 4.2 (42) for start and end voltages respectively.maybe i will take a peak this weekend and find out, pretty sure i still have one those bafang cables lying around.
My numbers are for the generic half twist. Best method is to measure the actual of your particular throttle for the widest range.
Be very careful setting the start voltage as if set on the borderline you could get instant throttle when the bike is turned on. Set too low should throw an 04 error
