PCS15
- USA
I am new to the forum and am hopeful of some feedback on purchasing my first e-bike. Thank you in advance for your assistance!
Rider: Female now able to use senior discounts! 5’ 10” 200+ lbs
Reason for the ebike:
After a knee replacement with significant complications, I have been unable to ride for several years. I have now succeeded in reaching the range of motion necessary to pedal a bike but still have knee issues. I need to minimize stress on the knee even now.
Previous typical rides averaging 20-25 miles: (Specialized Tricross Sport Triple (2009))
1. Very hilly back country roads
2. Combination of crushed rock rail trail and hilly roads
3. Acadia National Park crushed stone carriage trails through mountains
Ebike Requirements:
I am comparing the Trek Verve+ 3 Lowstep and Cannondale Adventure Neo 1 EQ. The Neo 1 EQ is a step up – has a more powerful motor, battery, suspension fork, integrated radar and better components. Due to tax differences based on where I would purchase the Neo 1 would cost me approximately $750 more. I have included some of the specs below. A third option would be the Cannondale Adventure New 2 EQ. This has many of the same specs as the Verve+ 3 with the addition of the suspension fork and is comparable in price.
I can buy the Trek at my local Trek store. The Cannondale I would have to travel a couple hours to find it in stock but do have authorized dealers close by at REI and a LBS. I have test ridden (in a parking lot) the Trek and am planning to take the day trip to ride the Cannondale. I like the looks and color of the Cannondale better. I also like the idea of the more powerful battery and motor and integrated radar but with not ever having an ebike do not know if they are fully necessary. However, I do not want to regret not spending a little more money for upgrades to reduce worry.
I am interested in thoughts from those with ebike experience on these two bikes and their specs and cost. Thank you in advance.
Ebike Requirements:
- Step-through due to loss of mobility
- Upright comfort geometry – want to use this bike for many years
- I do not want to have to worry about not having enough power for hills or the battery running out. I will be riding with my husband who is very fit (and will be embarrassed at being with me on an ebike!)
- Radar – I am hearing impaired and have decided this feature is a worthwhile safety investment (know I can add this on as well)
- Class 1 – cannot ride class 3 in national parks
| Brand | Trek | Cannondale |
| Model | Verve+ 3 Lowstep (size L) | Adventure Neo 1 EQ (size M/L) |
| Motor | Bosch Active Line Plus, 250 watt | Bosch Performance Line Cruise |
| Max Torque | 50 Nm | 65 Nm |
| Max Support | 270% | 300% |
| Battery | Bosch PowerTube 500Wh 6.4 lbs | Bosch PowerTube 625Wh 7.7 lbs |
| Range | 30-75 | up to 85 miles |
| Controller | Bosch Purion | Bosch Purion |
| Battery Warranty | 2 yrs/500 cycles | |
| Charge time | 4-8 hours | |
| Charger | Bosch compact 2A | Bosch 2A |
| Weight | 54.61 lbs | 57 lbs |
| Frame | Alpha Platinum Aluminum, Removable Integrated Battery (RIB), smooth welds, rack & fender mounts, internal routing, kickstand mount, 135x5mm QR | SmartForm C3 Alloy step-thru frame, removable downtube battery, fully internal cable routing, post mount disc, dual waterbottle headtube mount |
| Fork | Alloy rigid fork, 1-1/8'' Threadless steel steerer, 460mm axle-crown length (suspension corrected), ThruSkew 5mm QR Verve Alloy, threaded steel steerer, rack mounts, post mount disc, 460mm axle-to-crown, ThruSkew 5mm QR | SR Suntour Mobie A32, 63mm travel, coil with preload adjuster, lockout, crown light mount, 44mm offset |
| Tire | Bontrager E6 Hard-Case Lite, reflective, wire bead, 60tpi, 700x50c | Kenda Kwick Seven.5, 27.5 x 2.20" |
| Brakes | Shimano MT200 hydraulic disc | Shimano MT400 hydraulic disc |
| Shifter | Shimano Alivio M3100, 9 speed | Shimano Deore M4100, 10-speed |
| Rear derailleur | Shimano Alivio T4000, long cage | Shimano Deore M4100 |
| Cassette | Shimano HG200, 11-36, 9 speed | |
| Seatpost | Alloy, suspension, 31.6mm, 300mm length | Cane Creek Thudbuster G4 suspension post, 31.6, 375mm (S), 430mm (L) |
| Handlebar | Bontrager alloy, 31.8mm, comfort sweep, 660mm width | Cannondale E-Series Alloy, ergo backsweep, 680mm |
| Stem | Bontrager alloy, 31.8mm clamp, adjustable rise, Blendr compatible, 105mm length | Cannondale 3 with Intellimount, Alloy, 31.8mm clamp |
| Light | Spanninga SOLO for e-bike, taillight Herrmans H-Black MR4-E, 120 lumen, 40 lux, LED, headlight | Premium front and rear lights, premium fenders, rear carrier, Garmin radar |
| Radar | add on for $150 | Garmin integrated |
