Hyper-bike Walmart online
So you can get bike spokes of any size or the order those on eBay or Amazon,Thanks for the offer about the Hub,You can get a hyper ebike controller for like 15 bucks on eBay,You are still probably just would want to buy a Hyper bike for 400 because I'd have to get all the components and use the parts off Of,Yeah I think I'll research the bike spokes, yeah even if I had the Hub I would still and I I'd still have to get all the components go with it if I was successful,But if you're not using it and don't need it yeah take it it's just let me know what we need to do thanks,
Here's a link to a discussion about spoke replacement which includes links to places that can supply the spokes:
Hyper Spoke Replacement
On regular bikes, the front axle is 100mm, while the rear axle is 135mm. Older bikes vary a little on the rear. This makes it difficult to take any rear hub motor, and respoke it for a front fork, unless you can change it to a fat tire bike fork, which is generally 135mm.
Good luck with $10 spoke orders unless you're just talking about a few, If you want a set cut exact to your needs to the nearest mm. you have to go to a US seller. Expect to pay $40 or more for a set of 36.
Custom spokes on ebay
FYI:
A facebook hyper owner (the $398-598 model) has posted that he opened his controller box and found three solder pads to attach a throttle, addressing one of the limitations of that bike. Since I've not done, I'll copy what he wrote..
How to add Throttle to Walmart Hyper Ebike Controller,
"if you open the motor controller and take it out of the aluminum case you will see sp-, spd, and sp+ on the bottom. these 3 correspond to the throttle red = +, black = -, white = spd."
FYI:
you can get a controller for throttle control, that would be the eazy way , i like peddling ,you can get a 35e battery and get 10.2 amps you take off like a rocket not like the slow 7.8 amp battery
