Did you give it a nice massage as well at the spa?I decided to splurge and send my chain to the SPA for a hot wax treatment. Lol
Runaway Bike HOT TUB Paraffin Wax Chain Lubricant, Sports & Outdoors - Amazon Canada
Runaway Bike HOT TUB Paraffin Wax Chain Lubricant in Sports & Outdoors.a.co
It was too much money to buy the paraffin wax, Teflon powder and the Molybdenum Disulfide powder separately, so I bought the prepackaged stuff.
You just put the bag in a pot of boiling water and throw the chain in the bag and cook it.
Pull the chain out when it's done, and seal the bag up and store it until the next time you need it.
I have the chain off the bike now, so I want to get it treated and reinstalled before my new off-road display arrives, so that I can give everything a test drive.
I strap mine down with a Velcro strap even though I haven't had any problems.It says "NO TEAR OFF".
View attachment 143304View attachment 143305
I don't need to tear it off. It removes itself in no time.
I wonder if it is designed to void it's own warranty? They'll just say that I removed the sticker to open the battery case and I voided my warranty.
I would just heat the sticker with a blow dryer to remove it, then stick it back on after I had the battery case put back together.
I'm not too keen on the Reention design.
The plastic holders are too flimsy for a 10 pound battery and the whole mechanism is still moving around even with the screws replaced and tightened.
The battery is still bouncing around.
Reention needs to redesign their battery holder/lock.
A heavy battery needs a heavy duty clamp.
I'm going to keep strapping down the battery so it doesn't break.
I didn't realize you received the display. This is the so-called "offroad display" from Australia? Did you have to do any messing about with connectors? Or was it plug and play? I guess without even riding it, you can see if it allows you to set Turbo, Normal, Eco -- which the stock one didn't. I think I mentioned that I didn't see a hell of a lot of difference with these settings, but settled on Eco as it felt slightly more natural.The weather is supposed to warm up and dry up by next week, so I should be able to get out for another test drive with my new display.
Yup (New Zealand actually, but close enough. Lol)I didn't realize you received the display. This is the so-called "offroad display" from Australia?
NopeDid you have to do any messing about with connectors?
YupOr was it plug and play?
YupI guess without even riding it, you can see if it allows you to set Turbo, Normal, Eco -- which the stock one didn't.
Can't recall if we talked about this, but if you really don't want the PAS at all (which is pretty close to what you would do if you set max PAS speed to 6 kph), I suppose one could disable or disconnect the PAS sensor?Yup (New Zealand actually, but close enough. Lol)
Nope
Yup
Yup
View attachment 143322View attachment 143323
Yeah you did.
I was hoping the Australian display would make a more of a difference with my bike.
I wasn't settling for ECO,
That's that's what I hoping for.
Turns out that it has made no damn difference at all. lol
My last remaining hope is that if I turn the damn thing down to 6 kph, that it won't launch me to that speed in ¼ second.
Should be interesting to see how those different settings affect the ride.I will probably just turn my PAS mode to 0 in the settings to turn it off.
But first I want to try PAS mode 20 and throttle mode 20 and 6 to see if the acceleration is reduced as well as the top speed.
View attachment 143355View attachment 143356View attachment 143357
I'm hoping that if I turn my throttle down to 20 kph or 6 kph that my throttle sensitivity will be more granular?
It only takes me 10 seconds to enter the settings and change them, so I could pull over at the start of the dirt trail and turn it down for the dirt, then turn it back up when I get back on the road.
I also did a bit more on that Reention battery I had disassembled. Not 100% sure, but I think it may be a BMS problem. It charges OK thru the discharge port and I only took it up to around 49V, but I'm pretty sure it would have continued. I just didn't want to fully charge in case cells were out of balance and some would get overcharged. However, on the charge port the charger only sees about 33V, so naturally it won't charge. I'm trying to source a BMS. The trick is getting a small one that fits. Most of them don't support the on/OFF switch or the lights that show charge level, so not sure I'll get that part to work.
Actually I'm not sure why I'm doing all this as it's only a 13Ah battery and I already have 2 bigger ones!
