Carbon Wheel Build with Ebikemotion
Looks good. Forgot about the factory hub&disc being 6 bolt instead of center lock. Not going tubeless?
These are actually tubeless I just installed the tires and tubes temporarily until I get everything laced and will convert tubeless set up. The hub I selected DT Swiss 350 only came in center lock and Windy from Farsports provided the adapter
I hope the picture is clear when I find someone to replace my rear wheel I will post follow up pics. Yes this is going to be tubeless set up Yes it's center lock hub however the lock ring is provided to use the current disc brake compatible w the DT Swiss 350 straight pull hub
Dam already? Is it the hub? Keep us posted. Sorry about that. My rear wheel is currently with a wheel builder and I will post length of spokes and what type was used. This will be for same dimensions for Zipp 303 wheels
Ha Ha; I have the same bike although mine's in the shop for a motor issue... :(
What's wrong with the motor? I actually have 2 extra hub motors. I bought 2 new takeoffs that were on US spec Cannondale Neo's so I could build my rear wheel while still retaining the factory wheel/hub assembly intact. Orbea and Mahle will try to tell you that the hubs are registered to the bike and another hub won't work blah blah blah. That's not accurate. The battery/controller assembly is the only component that's registered and electronically signatured. As long as the motor is the correct US or EU spec for your bike, the system works fine with a different hub motor.
I'll keep you posted. I think it's the PAS sensor but it could be the battery or wiring. I like the feel of this bike (I can actually ride this bike with the motor off just fine) so I'm disappointed that the motor isn't working.
PM Sent
PM Sent
My spokes for my rear wheel arrived today the measurements was for 240mm this is same rim as the Zipp 303
It's finally finished my Farsports carbon wheels upgrade it looks amazing special thanks to Super6 Neo for hooking me up with the wheels and feedback
I didn't care too much about the color scheme so I changed it up a little
I ordered 2 more set of carbon wheels from Farsports and picked them up today Windy the rep for Farsports is so awesome to work with I am about to get the rear wheels assembled the front ones arrived already put together. The wheels are for a couple of friends who ordered a Cannondale Super Six Neo and an Orbea Gain. It took less than 30 days from the time paypal payment is made. The wheels are made to order and I am very happy with my set
