e-levity
We decided to convert Mrs levity’s Vado SL EQ to a GQ, i.e. make it a gravel bike “fit for a Queen”.
We used bits we’d saved from her previously modified Vado 6 and Creo to customize a new Medium sized SL:
EQ parts: Remove the lights and fenders since we’re fair weather riders in southern California. Keep the kickstand, it rocks!
Handlebars: Replace the OEM bars with Answer carbon 20/20 bars (20mm rise and 20° sweep for hand and wrist comfort). Bars were shortened to 700mm wide, but are 20mm wider than the OEM bars providing more control leverage.
Handlebar height: Lower the bars to a more aggressive position by flipping the stem down and inverting the bars to give a further 20mm drop. This put the grips level with the seat. Removing the stem spacers and using the 15mm shorter “duckbill” topcap was not enough. A pad was installed on the top tube in case the lower handlebar controls hit during a crash.
Dropper post: PNW 90mm dropper internally routed with Wolftooth bar remote.
Wheels: Light Bicycle carbon rims, i30mm, DT Swiss 350 hubs.
Tires: Panaracer GravelKing SK 27.5 x 1.9. These measure 53mm (almost 2.1”) at 30psi on the i30 rims and have plenty of clearance in the fork, seatstays, and chainstays.
Seat: Ergon Core Prime for the ultimate in comfort.
Some beauty shots -
and enjoying it in the real world -
The larger tires provide great traction and extra cushion.
Warning: the wide, low bars and low bottom bracket invite hooliganism!
Some beauty shots -
