Rear hub and mid drive motor working at the same time. what is the the outcome?
The short answer is "yes". You will need two separate motor controllers, and yes you can use separate batteries, or combine your batteries safely by using a "reputable" parallel battery adapter similar to this: (make sure you know what you are doing running batteries in DIY parallel)
My first question is why would you want to do this? What are you trying to achieve? You should have a really specific need that cannot be achieved with one or the other.
Assuming a properly configured transmission, a sufficiently powered (high amps) mid-drive, or rear hub, will deliver more power than you need for any road biking. For off-road biking with a lot of long duration steep climbing, or steep climbing at low speeds, I would recommend a mid-drive.
If you are asking how it will affect your ride and handling, there is some anecdotal data on that around these forums and on YouTube. Take a look at at this dual front and rear hub configuration from Eunorau.
"Take a look at at this mid-drive/front hub configuration from Eunorau using a Bafang BBS as the mid-drive."
Er, looks like two 750w hub motors to me and as described by Micah....
Mechanically you could use a mid drive and a rear hub motor as the hub motor doesn't have any effect on the drive train that the mid drive is activating. As mentioned getting the two powered up and coordinated electronically to sync together for a relatively seamless ride is another story.
If you are asking how it will affect your ride and handling, there is some anecdotal data on that around these forums and on YouTube. Take a look at at this mid-drive/front hub configuration from Eunorau using a Bafang BBS as the mid-drive.
I made the mistake of buying my first ebike without thoroughly doing the research. Now I am stuck with a ebike that lacks power. Now I can sell the bike and start fresh or add on to it and make it a more capable bike that can do everything I want. My goal is to climb steep dirt roads or trails and be able to pull a hundred pound bike trailer for bike camping like the Burley flat bed trailer.
If you really need to throw away some money and want an even heavier bike, go for it!
I made the mistake of buying my first ebike without throughly doing the research. Now I am stuck with a ebike that lacks power. Now I can sell the bike and start fresh or add on to it and make it a more capable bike that can do everything I want. My goal is to climb steep dirt roads or trails and be able to pull a hundred bike pound trailer for bike camping.
Got it. Sell it stock. It is worth more that way. Get a good bike from Craigslist. Something like a Boda Boda. Install a mid-drive. These bikes have extra-strong wheels. You will also want to upgrade the tires. Super Moto-X goes just about everywhere, or something more off road by Schwalbe. You likely will not need the trailer. The running boards and rack hold something North of 200 pounds. Use an ebike chain from KMC. A Nuvinci CVT cargo hub would be nice but is not necessary if you install an 11-42 with a long cage clutch derailleur. It also looks better when you remove the ugly extra wires and connectors.
Another person who wanted to throw away some money! PT Barnum was right!
I am currently into this ebike for 2 grand and adding a mid drive is another 1500 ish. So at the end I end up with, I agree a heavier bike but will have two bikes in one for 3500. I will post more if I go through with it. But in the mean time I would appreciate more helpful thoughts or advice that anyone might have.
My vote. Either sell or keep that bike as an extra. Then find the best deal on an Ultra or BBSHD powered bike. They both claim to have the same amount of torques, but the Ultra will be the one that can handle overheating the best. It's also a little heavier....
If you keep the bike you have, you'll have 2 bikes for 2 different purposes. The best of both worlds. The geared hub for it's ability to get on and ride in brain dead mode, and a geared hub for it's ability to climb.
what brand/model of bike did you purchase?
Error corrected, thank you JRA.
What do think about this mid drive system?
First thing I thought of was to get a regular rear wheel and a BBSHD which would simplify things and give you plenty of power and climbing ability by going through the drivetrain. Then looking at where your battery is, in the top tube, that even though beefy does not look like it will hold more than 500wh of battery @ 48v your range will be pretty minimal, certainly not enough to support two motors. Adding another battery could be an issue but not unsolvable. You definitely don't have enough stock battery to support that CYC motor at the level advertised.
Cheapest solution would be to put a chain ring with say 32t on the front and as big of a freewheel/cassette low cog cluster as you can source on the rear wheel and try to pedal on top of the motor you have. You will not be roaring up the hill but with the combined efforts you will get there eventually.
This bike needs more power as I am not able to climb steep hills or steep dirt roads. Also I would like to pull a bike trailer like the Burley flat bed. I am not in it to go fast or to tearing down public roads but more torque. More off road capability.
I put a 2000w hub on the front along with a 2000w rear hub motor..tons of fun 👍👍
