PedalUma the derailleur is as close as possible without rubbing, but even if it wasn't I don't think adjusting it would help one bit.
Look at the chain cross photo I posted yesterday (22). The cross chaining from the front ring to the smallest rear cog is huge. I rough measured it at approx 30mm.
It should be near straight in 6th gear. If not,
either the stock ring adapter is reversed for your bikes width, or you require a larger offset adapter.
Your photo looks like your chain would be aligned in 10th gear. That say's you need to offset the distance of 4 cogs.
Buying an offset adapter that allows you to use generic ring gears can't be bad. To me it's a basic must have.
By moving out just a tad, you can run anything reasonable to get your particular combination without being too close too the stay.
My understanding is as you say,
the 11sp would be better than the 12 ... and a 9sp would be ideal - my (cough, cough) opine.
I reason (cough, cough): a 9sp 48T with 48 x 12 gears maxes low 40's; Cruises in 23 to 33 range with; - in high gear.
It has 6 teeth on the chain, not 5 like the 12sp; the derailleur travels 1/3 the total range to shift and your chain line is
1/3 less off kilter in highest or lowest gears than a 12sp.
So, 1/3 of twelve being four,
in the your highest 12sp gear your chain would be aligned as you're now aligned in eighth gear and your lowest in fourth - but with an additional tooth gripping in the high gear cogs.
This affects me too.
If I'm incorrect, someone should tell me. The clock is ticking on my order. I can see in a straight line and that chaps my hide.
I expect performance that adheres to the the known standards.
Deacon's chain line is impossible for a reliable City - Anywhere - Cross Tour.
On the other side, I don't rage at Pushkar. These bikes don't come road tested -
though instituting a policy of testing the rear assembly, being certain the chain alignment is centered correct when in the middle gear is not too damn much to ask either.
There are no problems, only solutions.
The more I learn, the less I like these wunderkind improvements. I'm here for the Titanium Ultra. The form that fits the function is my outlook.
