DaveMatthews
Dave's not here. Cheating since 2018
- Canada
Hmmm...Any advice on a very difficult to release battery on Stance E+. Its a brand new bike and the dealer is a long way away so I can't easily take it back. The key will turn a bit but not release, after lots of attempts it eventually engaged and I was able to release the battery. I lightly lubricated the catch and put it back and now i can't get it to release again.
I know from experience that some Stance have shim plates installed under the battery connector in the frame. Perhaps that is what has over tightened the connection.
I wonder if you could very gently put a plastic wedge in at the top if you could assist in the release of the lock.
Not sure because I'm not a mechanic. Maybe a tire lever or something?
Once you do get it open, I've also heard you can adjust the lock mechanism.
