Bike trailer
So far, I like this: https://www.amazon.com/dp/B01N260A8D/ref=cm_sw_r_cp_apa_glt_fabc_AWACX90E5F7QDAH7JWYG
This: https://www.amazon.com/dp/B0937MGG1Y/ref=cm_sw_r_cp_apa_glt_fabc_0KDNKSFECEXE6W4Y27MH?psc=1
And this: https://www.amazon.com/dp/B0029KKQSK/ref=cm_sw_r_cp_apa_glt_fabc_FJS7Q8N20R31ENR2B2TD
The higher sides, supposed foldability, and options for cover appeal to me.
I do almost all my grocery shopping at a military commissary on base, so I'm not extremely worried about the bike (locked, of course!) and/or trailer being stolen while I'm in the store, but I would like the option of using the trailer as my grocery cart. That's only possible with the Aosom, I believe.
Also wish brighter, more visible color schemes were the norm!
Anyone have a good trailer to haul a 2 yr old grandchild around? Safety straps etc...
What’s your budget? I thought my Burley Encore X was pretty expensive before I bought it. But now I think it’s a great value. It’s fun and comfortable for the kids and has added so much hauling ability to my bike when I’m grocery shopping or doing a Costco run. If it’s something you think you might use a lot, it might be worth spending good money.
Added this to make my own “tow truck “.
My $100 schwinn trailer has turned into a best buy.
I’ve used a Burley that my daughter and SIL bought for hauling my two yr old grandson. Works very well and you could haul other stuff in it of course.
I can appreciate the shopping cart idea but I’m not a fan of attaching some heavy pulling to the seat post. It would also be in the way of a trunk bag. At one time I saw a trailer that attached to the bike rack but can’t find it again.
I'm hoping the arm will pivot and I can at least use it like a wagon 😜
The Aosom Trailers have a T-Grip handle on the towing arm.
I use my Aosom Trailer as a wheel barrow too.
On your Aosom trailer could the bracket that attaches to the seat post be rotated 90 degrees to attach to the end crossbar of a rear rack and still work?
I like the one that is 2 in 1 for grocery shopping and riding a bike. Just put a DOT triangle on the back.
Yes the trailer tow arm would attach to the Clamp rotated 90 degrees.
But it's not designed to attach to a bike rack.
A bolt on frame bike rack would twist.
A welded to the bike frame bike rack would be sturdy but the clamp is designed for a seat post tube diameter.
And attached to the rack the tow arm and trailer would be really extended far away from the rear wheel - not good.
I have a Rad Rover but I doubt I'd use a trailer with it. If I did it would have to attach to the rack. I have a Rad Mini ST that was just shipped. If I get a trailer it will most likely be used with the mini. I think, but won't know for sure for a few days, that the trailer tongue will clear Mini's rack.
