J3ON
- Canada
I finally found were to get the cable with the right connector for the taillight, if you're interested it's at greenbikekit, it turns out they're quite well equipped in parts for the G510.
For those who may not know it by opening the the panel where the wiring is located there are two blue connectors, one is already connected to the headlight and the other one is for the taillight and you'll need an extension cable long enough to connect it. You can always remove the blue connector and extend the wires yourself but that wouldn't be as clean as a job.
