Shogun7s+
- USA
Just got an Allant+ 7s last week (will post thoughts on that later), but currently wanted to see if anyone had mounted a U-Lock to it and if so where they put it.
I purchased an Abus 540 U Lock, but struggled to find a place on the bike that it would fit w/o blocking my boss mounts (mounting it in the triangle would block using anything else in there), getting in the way of pedaling/the rear wheel, blocking items on the rack or rubbing against my leg.
Some of the issues compared to my last bike are that the frame is too thick for the lock holder in many places and thicker tires cause the frame to flare out for the rear wheel which makes it difficult to mount there.
After trying a lot of different locations, I eventually decided on the location below, which is ok but wondering if anyone else had a better mount.
The current mount which is not too bad, just seems a little out of place - one of the advantages here is both the U and the shackle (which is very heavy) will not fall out of the mount as soon as it is unlocked.
Tried this location, but it would rub on my leg when pedaling (on my last bike I had it mounted simialarly, but below the seatpost - unfortunately that does not work on the 7S as the wheels are thicker and the frame juts out).
Tried this, but couldn't get the mount tight enough to stop the lock from moving (and potentially impeding the tire) while riding
