I have a Rambo Krusader 2.0. Yesterday, after my ride, I tried to remove the battery, but the latch wouldn't release the battery. Has anybody else ran into this issue?
I called Rambo Customer Support and they suggested that it might be the latch on the battery. I was able to remove that battery and try my second battery today. However, it also won't release, which is leading me to believe that it might be the lock itself.
Is it worth trying a spray on
This is what the AI Overview gives me.
Rambo e-bike battery lock failures, often resulting in a stuck or unresponsive key, are typically caused by dirt, damaged internal pins, or misaligned locking mechanisms. Immediate fixes include lubricating the lock with dry graphite spray, applying gentle pressure to the battery while turning the key, or, in severe cases, disassembling the casing to access the mechanism directly. [1, 2, 3]
Here are the most common solutions and troubleshooting steps based on reported user experiences:
1m
Battery removal device wisper e-bike lock override
The Frothy Bike Co
YouTube• Sep 24, 2024
If the bike is under warranty, contacting Rambo Bikes for a replacement part is recommended as this is a known issue for some users. [1]
This video explains how to repair a jammed ebike battery lock:
Repairing a jammed ebike battery lock Part 1.. follow for part 2…
richeewrightvlogs
TikTok• Jun 25, 2024
For more information, consider searching for:
- Lubrication: If the key turns but doesn't release the battery, the mechanism may be dry or dirty. Apply a dry key lock lubricant or graphite spray, not wet sprays like WD-40, which can attract more debris.
- Pressure Management: If the battery is wedged against the lock, try pushing the battery forward or upward to relieve tension on the locking pin while turning the key.
- Replacing the Assembly: If the lock barrel is broken or the key spins freely, the lock assembly is damaged. Users have reported that replacing the lock assembly is a common fix, often with more durable, aftermarket, or upgraded metal parts.
- Disassembly/Override: If the key is totally non-functional, the battery case screws can be removed to remove the battery and expose the lock mechanism for manual release. [1, 2, 3, 4, 5]
1m
The Frothy Bike Co
richeewrightvlogs
- Rambo bike key stuck in battery
- How to unlock Rambo bike battery without key
- Rambo bike battery lock replacement parts [1, 2]
- Anyone ever have the battery lock fail. Any suggestions on a quick fix?
Oct 3, 2025 — Any suggestions on a quick fix? ... Unscrew the bolts the other side and close the battery cover and then tighten the bolts. I res...
Facebook·Scor 4060 Z LT Owners Club
- Ebike battery lock not releasing battery - DoItYourself.com
Mar 4, 2025 — Read everything below before doing anything! Get a liquid degreaser and test it on a hidden area of the cover to make sure it does...
DoItYourself.com
- Vandalized E-Bike Battery Lock : r/ebikes - Reddit
Jan 6, 2026 — Easy. Remove all battery case screws. Replace lock assy. Comes with 2 new keys. Done. ... i once lost key for my e-bike battery, s...
Reddit·r/ebikes
