That's the adapter that you attach to the underside of your trunk bag/box.Have you thought about this: https://www.rosebikes.de/racktime-snap-it-adapter-555514
I know some German forum members have used this successfully.
Thanks, Ravi. I actually have one of these. As @antboy pointed out this converts a non-racktime basket or bag to work with a racktime rack.Have you thought about this: https://www.rosebikes.de/racktime-snap-it-adapter-555514
Personally, I've never seen a simple adapter plate that can be added to the rack to make it RackTime compatible.I have a Racktime rear bag as well as their grocery basket. I am looking to add racktime fittings to an existing, integrated rear rack on a Riese & Muller Delite. If anyone is aware of a kit or adaptor that can be secured to that rack, I would be most appreciative.
Yes, thanks for sharing your thoughts and explorations. I already have the bags and baskets I need, I just need to figure out how to attach them to an existing rack. I do have a racktime beam rack that mounts with a seatpost clamp. In the case of the Delite, that would entail removing the nicely built lower Seat tube mounted factory rack. I would rather adapt that to accept my bags and basket. I will try to tack down the MIK rack adaptor if it is indeed racktime compatible as well.Personally, I've never seen a simple adapter plate that can be added to the rack to make it RackTime compatible.
I was tempted to either buy the ClipIt, and repurpose the top plate on fixed rack, then started sketching out my own adapter, but ended up selling the bike that didn't have RackTime, so stopped.
If you don't mind switching systems, I believe the KLICKfix that @GuruUno linked to has the same screw placement as the SnapIts on your existing bag/basket.
EDIT to add: From researching a couple of years ago, you MIGHT be able to find a plate that is both MiK and RackTime compatible. I remember coming across something like this, but I don't recall who made it.
I wish there was one system out there for them all. To be honest, I'm half tempted to convert all 3 bikes to Topeak, because that seems to rule to roost here in North America.![]()
I am looking to convert an integrated Riese & Muller Delite Mountain rack with no racktime fittings, to be able to accept the Racktime bag and basket that I used on my Homage, which is being sold soon.
I am thinking of picking up one of these, scrapping the mounting legs and license holder and working our a hardware system to securely fasten it to the top deck of my existing rack.
I used a similar approach to attach my collection of Bontrager Interchange bags to my e-bike rear rack. These insulated cable clamps work very well. They are sturdy and don't mar the bike finish:
View attachment 88716 View attachment 88717 View attachment 88718 View attachment 88719
WiMas 50pcs Pipe Clamp Rubber Cushioned Stainless Steel Cable Clamp Mounting Pipe Clamp Insulated Cable Clamp 1/4'', 5/16'', 3/8'', 1/2'',5/8'' for Tube, Wiring, Cables, Pipe, Rack, Line Restoration - - Amazon.com
WiMas 50pcs Pipe Clamp Rubber Cushioned Stainless Steel Cable Clamp Mounting Pipe Clamp Insulated Cable Clamp 1/4'', 5/16'', 3/8'', 1/2'',5/8'' for Tube, Wiring, Cables, Pipe, Rack, Line Restoration - - Amazon.comwww.amazon.com
It isn't pretty but the scheme has worked for 3 seasons and over 3000 miles without any issues.
