Ugh ...
Thought I'd change our the stock pathfinder 38c for Smart Sams 40C. Tires look like they would have great traction. Unfortunately, I could not get them onto the rims after about 45 minutes of struggling with it and watching numerous videos on how to do so. I could get one side and 80% of the other, but it just would not go. At this point I'm likely sending them back; even if I had the LBS do it, what happens when I get a flat on the trail?
Worse, when I removed the rear wheel, I didn't set the gear to the smallest setting. Once I get it back on, when I shifted all the way to one end of the gears, one one side the front hub would not spin, and the other end of the gears the chain came off. And, the chain proceeded to come off the front hub and get stuck between the front gear and the motor housing. After wrestling that for a while I got that fixed, but I cannot get the rear gears right. Now it seems that the derailleur is in the way. I have no idea what to do other than take it to the LBS tomorrow.
I'm pretty disappointed and frustrated.
