So I spoke with a couple of you guys here 1-1. Thanks
@brake034.
I wanted to follow with a slightly deeper background based on some testing we did a few months ago (and continue to do).  Please note that
these issues apply to all motors - not just Bafang.
1. The way the gears sit in a mid drive e-bike motor (typically) is based on the motor casing and positioning of the stator / core etc.
2. The tolerance for these motor casings is low. Across different production batches, you may see ±0.25-0.5mm change. That is significant.
3. All machined gears are also made with loose tolerance - sometimes deviation is as high ±0.1-0.3mm
Note: For this discussion I am ignoring the thermal sink issues (motor heating , lack of effective cooling).
With loose tolerance, riders will notice the following
1. Louder noises - as gears rotate, the higher the effective gap, the louder the noise. I have tried Bafang and  bosch Gen 4- both motors have the "noise".
2. As you ramp up to higher speeds (and higher RPM), because the Ultra is all steel internally, there is a rapid increase in temp due to these tolerance issues. The motor doesnt get too hot because it has a fairly large heat sink.  This heat issue is present in Bosch though- if you go turbo, thermals are comparable to the bafang m600  - too much power in a smaller enclosure.
3. If we put 30 amps through bosch / yamaha / etc, the gears will absolutely start to fail (IIRC most are actually nylon!)
With that background, a Single PEEK gear for the bafang ultra IMO is not a sufficient solution. It may work for lower power motors (say 300-500W nominal) , but with  higher wattage, high manufacturing tolerances, we should absolutely expect a higher failure rate with PEEK.
So why are the motors made with loose tolerances?
1. Cost. tightening the tolerance adds (anecdotally) 25-50% increase in production cost.
2. Manufactuers may also need to re-do molds and tooling. It is a one time cost but significant enough investment upfront.
Which are the quiet motors then ?
1. Brose and Yamaha motors appear to have better tolerances than Bosch, Shimano,  Bafang (Anecdotally).
2. Lower wattage will allow any manufacturer to do all PEEK without addressing the tolerance issues.
 The ideal way to tackle noise / weight / heat  is to take a holistic approach
1. Better tolerances on casing.
2. Better tolerances on gears.
3. PEEK for ALL gears, not just the primary gear.
This allows for reduced noise, better gear inter-locking, and noticeable reduction in heat generation. This may not be the answer everyone is looking for,  and we may have short term success with a single PEEK gear . However it is not an effective long term /scalable solution.  The problem is much deeper, and it is not limited to Bafang. All ebike motors have (in general)  high tolerances, most just don't run into it because they have lower power motors.
If we want to look at mid-drives with nice motors, look at the new Zero motors drive train - IIRC, they actually reduced the motor shell size by a little in the new versions, as their quality has improved. Also, TDCM (the hub motors on stromer) - the higher end versions - very very tight tolerances.  OOh.. my fav is Pinion gear box. I know its a gear box- but it is beautiful. It helps to have a fluid bath
