pushkar
Yeah, but in context of better tolerances that I have seen.Oh, that Zero! So you're talking about e-motorcycle motors, not e-bike motors then (at least not yet ).
For what they're charging for their bikes, they better be!Yeah, but in context of better tolerances that I have seen.
ha ha.. yeah. I had been following up with their battery and charging unit providers for our bikes. It didnt work out but got a peek into what high quality production looks like. Very well done. They do have some glithches on the software side though, that is typically an afterthought, but manufacturing is quite good.For what they're charging for their bikes, they better be!
I appreciate the really in depth analysis.....here is the comment from another thread when I inquired if anybody out there was still running the original OEM Nylon gear from when Bafang first came out with the Ultra.So I spoke with a couple of you guys here 1-1. Thanks @brake034.
I wanted to follow with a slightly deeper background based on some testing we did a few months ago (and continue to do). Please note that these issues apply to all motors - not just Bafang.
1. The way the gears sit in a mid drive e-bike motor (typically) is based on the motor casing and positioning of the stator / core etc.
2. The tolerance for these motor casings is low. Across different production batches, you may see ±0.25-0.5mm change. That is significant.
3. All machined gears are also made with loose tolerance - sometimes deviation is as high ±0.1-0.3mm
Note: For this discussion I am ignoring the thermal sink issues (motor heating , lack of effective cooling).
With loose tolerance, riders will notice the following
1. Louder noises - as gears rotate, the higher the effective gap, the louder the noise. I have tried Bafang and bosch Gen 4- both motors have the "noise".
2. As you ramp up to higher speeds (and higher RPM), because the Ultra is all steel internally, there is a rapid increase in temp due to these tolerance issues. The motor doesnt get too hot because it has a fairly large heat sink. This heat issue is present in Bosch though- if you go turbo, thermals are comparable to the bafang m600 - too much power in a smaller enclosure.
3. If we put 30 amps through bosch / yamaha / etc, the gears will absolutely start to fail (IIRC most are actually nylon!)
With that background, a Single PEEK gear for the bafang ultra IMO is not a sufficient solution. It may work for lower power motors (say 300-500W nominal) , but with higher wattage, high manufacturing tolerances, we should absolutely expect a higher failure rate with PEEK.
So why are the motors made with loose tolerances?
1. Cost. tightening the tolerance adds (anecdotally) 25-50% increase in production cost.
2. Manufactuers may also need to re-do molds and tooling. It is a one time cost but significant enough investment upfront.
Which are the quiet motors then ?
1. Brose and Yamaha motors appear to have better tolerances than Bosch, Shimano, Bafang (Anecdotally).
2. Lower wattage will allow any manufacturer to do all PEEK without addressing the tolerance issues.
The ideal way to tackle noise / weight / heat is to take a holistic approach
1. Better tolerances on casing.
2. Better tolerances on gears.
3. PEEK for ALL gears, not just the primary gear.
This allows for reduced noise, better gear inter-locking, and noticeable reduction in heat generation. This may not be the answer everyone is looking for, and we may have short term success with a single PEEK gear . However it is not an effective long term /scalable solution. The problem is much deeper, and it is not limited to Bafang. All ebike motors have (in general) high tolerances, most just don't run into it because they have lower power motors.
If we want to look at mid-drives with nice motors, look at the new Zero motors drive train - IIRC, they actually reduced the motor shell size by a little in the new versions, as their quality has improved. Also, TDCM (the hub motors on stromer) - the higher end versions - very very tight tolerances. OOh.. my fav is Pinion gear box. I know its a gear box- but it is beautiful. It helps to have a fluid bath
You can find Youtubers saying the same about Ferraris and Lamborghinis. The brand new car that cost half a million needs to be mapped, new exhaust, new wheels etcThere still appears to be a lot of stigma associated with “bafang”. By default a lot of people associate it with “lower quality”. There is always an argument to be made that the motor is so bad that it needs custom controller and quiet gears to compete.
Yes. Completely agree.E-Mountianbike had this to say about current motors from all brands.
"What are motor manufacturers doing wrong? The new Shimano EP8 also makes a metallic knocking noise when rolling over obstacles, just like the Bosch Performance Line CX motor introduced last year. All the ends bike manufacturers are going to to make bikes quieter seem to be in vain."
The point is whoever can bring this to market on the ultra will have achieved something all the big players have not, a very powerful motor with a throttle that is quieter, and many companies will want in on this.
Ok. Will keep everyone posted on how this shapes up. Hopefully we can get to a point that we test these in some form over the coming months.Yes. Completely agree.
Spot on.E-Mountianbike had this to say about current motors from all brands.
Public opinion: Generally derived from a lot of loose lips blabbing what they themselves have no understanding of.There still appears to be a lot of stigma associated with “bafang”. By default a lot of people associate it with “lower quality”. There is always an argument to be made that the motor is so bad that it needs custom controller and quiet gears to compete.
It is true that there is a premium performance space , but it adds significant cost that IMO few are willing to pay. Back of the envelope, it’s cost of motor+controller + gears = $14-1500 for just the motor. That’s fairly steep IMO. The better way is to just build it right from the ground up with the right parts, and target the 500-700 sweet spot.
Interesting comment with the top controller already in hand are you actually consider building you own motor in house ?There still appears to be a lot of stigma associated with “bafang”. By default a lot of people associate it with “lower quality”. There is always an argument to be made that the motor is so bad that it needs custom controller and quiet gears to compete.
That is really impressive, I am sure you will come up with something awesome, would you be looking at a patent for only Watt Wagon, or would you make it so you could sell to anybody to fit on most Ebikes.Long term, we need our own for sure. No doubt.
Current manufacturers move too slowly and design for 250-400W first. We have looked at atleast 20-30 different variations from various manufacturers from China, Taiwan, Germany, Portugal, Italy, etc etc. Most motors are commodities - like literally I spoke to the bofelli and fazua OE guys.
The development is not trivial, but given that we have figured out the controller part, we can actually apply this to pretty much any motor out there. Ideally we dont need to develop everythign from scratch, and take an "open" design and update it. We have a couple of promising candidates - but it is a super long term project 24months. Motor at small scale is no problem, but scaling means we need to consider partnerships, OE vendors etc.
I hope that the design of the motor casing/housing would make it retrofit into the current Helios/Hydra frames! And maybe halve the weight....Long term, we need our own for sure. No doubt.
Retrofit is definitely the goal.I hope that the design of the motor casing/housing would make it retrofit into the current Helios/Hydra frames! And maybe halve the weight....
