Ok, thank you. I am in touch with the Amazon seller who sold it to me as well. I was hoping it was something I could figure out on my own and I could learn something, but at this point, perhaps not!OOPS! I misread as a BBSHD. I'm thinking it's a controller issue. PAS device failures aren't common.
Wow that manual for replacing the circuit is fascinating! Thank you for all this info.Bafang/8fun bbs01b/bbs02b/BBS03/BBSHD PAS circuit for replacement-Greenbikekit.com BBS, ebike batteries, Bafang M620, Bafang M600, Bafang M500, Bafang M510, KT controller with display-GreenBikeKit.com
Bafang bbs01/bbs02 PAS circuit for replacement.www.greenbikekit.com
GreenBikeKit offers this,
"Bafang BBS01, BBS02, BBS03/BBSHD kit spare part: BBS PAS circuit with connector for replacement. It can plug into the BBS controller directly. If your kit cannot work with padel, but it can work with throttle, you can consider to replace the PAS circuit. To remove or install the PAS magnet, you may need a special plier and you can order the tool on our website too.
If you also need the magnet disc for BBS01/BBS02 kit, please click here: BBS01/BBS02 PAS magnet disc
If you need the manual for replacing the PAS circuit, please click here: How to replace BBS PAS circuit"
I'm sorry, the magnet on the speed sensor is what got knocked out of place.
				 endless-sphere.com
					endless-sphere.com
				PAS-FOR-BEWO-MID-DRIVE-
Bafang BBS02 throttle works but pedal assist does not - Electricbike.com Ebike Forum
I'm at my wit's end with this problem that I'm having and hoping that somebody here can help me troubleshoot. I bought a second hand Bafang BBS02, 750w kit. I put it on my bike and everything works except for the pedal assist. The throttle works fine, the walk assist works fine, but when I...electricbike.com
Thanks, but that isn't for the Bafang BBS02B that I have.I found this on the web for the location of the PAS which connects inside the controller cover, aparently there is a connector that could be disconected, but in the vides it's alittle hard to see which whir he is disconnecting .https://www.ebay.com/itm/PEDAL-ASSIST-SENSOR-PAS-FOR-BEWO-MID-DRIVE-ELECTRIC-BIKE-KIT-EBIKE-PAS-SENSOR-/124236443744.
I'll see if I can find that video again so you can check the connector.
				 electricbikereview.com
				Some don't know the difference between a speed sensor magnet and/or a PAS sensorRelevant?
I've seen strange behavior when the speed sensor isn't flashing as the magnet passes. And BEWO has NO relavence here.Some don't know the difference between a speed sensor magnet and/or a PAS sensor
Thanks. Yeah, I am definitely concerned about invalidating the warranty. Looking forward to seeing what the seller says!At about 2;32 on this video you can see the connector for the PAS sensor coming out from the housing that holds the crank. Edit: It shows up earlier but he never discusses it.
I think you will need a motor replacement under warranty. Perhaps your seller will not want the old motor back, but it's not worth going this deep if it invalidates your warranty. It could just be a loose connector, but it could be a bad PAS sensor, and you're not going to find it easy to get a new one.
Be patient... We'll get this figured out.Thanks. Yeah, I am definitely concerned about invalidating the warranty. Looking forward to seeing what the seller says!
Warranty? I'm sorry for the sarcasm, but too often resellers and even Bafang can be a PIA for warranty coverage.invalidating the warranty.
echo...Do you mind if I ask their name?
Really a lot more work than on a hub motor !At about 2;32 on this video you can see the connector for the PAS sensor coming out from the housing that holds the crank. Edit: It shows up earlier but he never discusses it.
