rochrunner
 - USA
- City
 - Rochester Hills MI
Can the bike be configured to use the auxiliary battery first before drawing on the internal battery? I've seen conflicting info on this.
			Yes. There is a toggle switch in customized ride settings in Mission Control whereby user can specify to use the range extender first. Any doubts and I can try to post a screen capture.Can the bike be configured to use the auxiliary battery first before drawing on the internal battery? I've seen conflicting info on this.
Thanks. This was just related to my pre-purchase research.Yes. There is a toggle switch in customized ride settings in Mission Control whereby user can specify to use the range extender first. Any doubts and I can try to post a screen capture.
Let me add that my Garmin 830 with the Ebike Field add-on shows 100% when both batteries are available and fully charged and appropriately decreases to show remaining power as the battery is in use. I have to use the Mission Contol App to see the actual charge levels. The on board display leds of course can be used as an approximation to the battery levels.I recently purchased a Range Extender battery. The initial charge took over three hours. The main battery generally takes about 2.5 hours to charge. Yesterday after about 80 miles it was time to recharge the rascals. It basically took all afternoon. First the RE and then the main Battery. My LBS has ordered the Y-cable for me, I hope it comes soon.... I really hope the cable will speed up the charging process. I don't see how the Y-cable can charge both batteries in less time than charging the main battery by itself...
It won’t. The charger will deliver power at about the same rate, so it will take about the same time as it would to charge them sequentially. The Y-cable just offers the convenience of not having to return to switch the connector. Disappointing. . . I don't see how the Y-cable can charge both batteries in less time than charging the main battery by itself...
Since the measurement methods are different, I wouldn't see the deviation as overly dramatic. I think the TCU delivers the safer result here. However, the charger should be able to recognize whether the battery capacity has been expanded or not in order to adapt the charging current. It's a shame that the respective charger cannot do this until today. Meanwhile, Specialized takes care of all kinds of electronic gadgets, just not what would actually make sense!Was Mission Control being a bit optimistic about the charge state?
