Gionnirocket
Well-Known Unidentified Member
- USA
- City
- Y. O.
I’ll work circles around ya. I’ll wrap your #$^&’ head in with a ratchet! I work on Race cars Tough Guys!!
I had my mechanic put Tannus Armour in all 4 tires when he put my two R1Up 700's together, in hopes they will help.In changing my tire yeserday, I did notice that the tire itself seemed awfully thin. I may explore the world of tire liners...
I can surely relate to this!I grew up amongst farmers that had to do daily maintenance on an untold number of mechanical machines on a regular basis or the farm didn't run. There is no way a farmer can call or run to a repairman every time something breaks or needs adjustments.
I grew up fixing things so maybe that is why I rather enjoy figuring out fixes on machines and doing maintenance on my bike. It gives me a feeling of satisfaction to have taken care of it myself.
I realize everyone doesn't have the ability to fix and repair mechanical stuff so it can get costly for those if they have a high maintenance machine.
There are times when we all tinker with stuff that is best left alone.
If it ain't broke don't fix it.
Without proper tools, why bother, right? Plus as much as I critique LBS locations I want them to survive. I had my eBike ( the accoustic side) tuned recently by a LBS. He bought the store end of January. He has totally missed the "boom" due to inventory shortages (Trek) . Anyway he has really fair repair pricing so I had him go over a couple of bikes I was selling and my Fattie. He knows he is competing with online so even his accessories are priced well. He is also a converted MTB'er , single track and D/H. He loves his full suspension Trek eBike.I feel comfortable tackling most general mechanical issues, replacing consumables, etc, but being a relative newbie to the e-bike scene, I’ll defer to the experts. A few days ago, my Creo was blown over by a strong gust of wind onto its drive side during a brief stopover and took a direct hit on the rear derailleur. It didn't shift right after that and I ended up taking it to my LBS to have the rear hanger inspected and re-aligned. I’ve heard of people bending hangers back into place using a wrench but without knowing if either/both horizontal and vertical planes were compromised, my preferred option was to have someone with the proper alignment tool carry out the job. Had them do a firmware update at the same time.
Good stuff!just got my bleed kit. trying to find the right kit with all the parts was just a pain. I have a Shimano brake set and a Magura so this does both and more. will attempt it tomorrow
It will be part of history once you switch to this ones. Thorn resistant tube. 20$ /piece for a permanent good bye to flats !!Except for a flat tire on my new
Flat911 do you do most of your own maintenance or do you use the LBS. And by the way, what is your fave Ebike?I had a similar impact while riding off-road and was able to realign the rear derailleur hanger.
The LBS made a good suggestion to order another hanger just in case it happens again.![]()
man what a messy thing to do
Probably no rule of thumb here. Given the way you and I ride ( going on your reports here) we can probably go a couple years or so between pad changes. Just guessing though.What is the general rule of thumb on how long hydraulic brakes last before they need to be repaired, bled, new pads etc assuming you drive normally no excess brake usage?
