Netherlands
The battery fire occurred while changing a broken controller. After connecting the battery to the system it caught on fire and was unstoppable. Cooling it down with water was the only option. That’s how I kept the damage to a minimum.
I did too until I found using ammo cans as safety devices. Two 20Ah triangles fit with room to spare.CSH said:
I got myself all loaded up with anxiety over battery safety
Netherlands
Not to criticize an unfortunate accident at all. But would a fire extinguisher be less likely to induce further electrical shorts and provide surer fire control than water?
And how do we find that information?with a track record of limited fires...
Fire extinguishers are useless with battery fires.Not to criticize an unfortunate accident at all. But would a fire extinguisher be less likely to induce further electrical shorts and provide surer fire control than water?
Good to know, thanks.Fire extinguishers are useless with battery fires.
Again, they do make these but not sure how they work with a large ebike battery.So what do you do if you encounter a battery fire?
