I asked Suntour whether their 31.6mm post would work in the StepThru 31.8 tube.
Their reply - "You will most likely need a shim to make the 31.6 seat post work on that bicycle."
A shim would have to be .01mm thick, to fill the .2mm gap(both sides) .
I can find no source for a shim which is that thin. I've checked Cane Creek, for example - no shim is even
close to being only .1mm thick.
Other than some "makeshift" shim (tape, tinfoil, etc.), does someone know from experience that the 31.6 post will be clamped sufficiently in the 31.8 tube, or know of some thin-shim source?
I am aware that some have hacksawed a vertical slot in the tube, allowing the two sides to be squeezed together, but I am not willing to do that.
Thanks for any replies ;-)
