Ok, I made it !!!
Interestingly I did not have any problem fitting the device ! There was not a lot of space, but surely enough. Maybe that's because I have a L-size frame, or maybe the Volspeed V2 is a bit smaller than the Bikespeed RS. I didn't put it in the battery chamber, just below, at the very bottom of the downtube, where the red arrow is on the picture.
The advice I would give here : don't pull out all the cables when you pivot the motor. There are just two that you need to unplug, identify them and plug the device while keeping the cables where they are if you don't need to move them. That way it was quite easy to put everything back together.
It still took me several hours, but the hardest part for me 1) understanding which tools I needed 2) the unmounting process itself, because it looked a bit different than all the tutorials online which were made on older versions.
So for the tools, this is what I needed on mine (Explore E+1 Pro 2020 with SyncDrive Pro) :
- 8mm hex key with a long handle - long handle is important to be able to apply enough torque, the nuts on the pedals are very tightly fastened and there is just no way to remove them with a tiny pocket tool (I tried and failed).
- 4mm hex key - needed to remove the motor cover.
- Crank puller tool + 16mm wrench (also long enough for the same reason as above, also tried and initially failed using one that was too small). You need a tool compatible with a ISIS drive, not Octalink ! (with the thick rotating tip)
- Giant spider + 1/2” torque wrench
- T20, T25 and T30 Torx keys
- Flathead screwdriver (to pivot the motor once unscrewed)
- I did not need the chain whip tool. You can use the rear brake to prevent the wheel from rotating when using the spider.
I had a short test drive with the limit upped at 32 km/h and it makes already a big difference with 25 km/h. With the Volspeed it is possible to set the limit with the remote without having to unmount it again.
Again thanks a lot for the support ! And hopefully this little feedback can help someone else
