New Front RIM
Hi All
Had an accident the other day: someone pulled out in front of me without looking, hit my handlebar. I hit a fence post and went straight over bars.
Needless to say, wheel is trashed. Took it to LBS. They said they can't source a new wheel. I presume I just need a rim. Anyone know where I can get one or what brand they are (and specs)
Thanks
Mark
. Tried LBS: they said they couldn't
I don't get why they couldn't. I don't know wheels well but it looks pretty standard. The thicker spokes? Hard to find a QR disc brake rim? (QR shouldn't be used with disc brakes anyway. Makes you adjust the brakes every time you take the wheel off, among other problems).
What are the specs on your current rim... width, diameter, and hub spacing?
Not sure. I'm afraid I don;t know too much about bike specs. just a rider
Product page says:
  • Heavy Duty SAPIM Spokes
  • Tire Size: 28 x 1.75 / 700c x 45c
  • 750 W Bafang Geared Hub Motor
  • 52V / 19.2 Ah Extended Range Battery
  • Tektro Hydraulic Disc Brakes
  • LCD Advanced Matrix Display
  • Torque and Cadence Pedal Sensor
  • 25 Amp Peak Controller
  • Schwalbe Marathon Plus Tires
  • 9 Speed Shimano Cassette Drivetrain
Product page says:
Based on your specs, you should be able to replace the entire wheelset for under $80... take a look at the Hybrid 700c CafeDisc Pro.
Hi All
Thanks
Mark
View attachment 56480. Tried LBS: they said they couldn't
Is there any damage to the rim, hub or spokes. If not have you tried to true the wheel
Thanks for reply. I don't see any damage. Truing it is way beyond my skill level. Will try a different LBS today. I'm a heavy rider, so want to be sure it's super strong. Would rather buy new wheel/rim if there's any question about damage to rim/wheel
Mark
