Cyklefanatic
What your asking for doesn’t really exist because high power and light weight are mutually exclusive. I also am assuming that you need fenders and a rack which add more weight.
Some suggestions. Don’t focus on the 90nm. Most of the torque numbers published are marketing hype and not directly comparable. So buy a light weight bike with a small motor and change out the front chain ring for something smaller. This will help with your big hill. But it will reduce your top speed, not sure if that is an issue. Another option is a cassette with a better granny gear that you can use for that steep hill.
You mention problems with walk mode. I can’t speak for all brands but walk mode should easily carry the bike and a heavy load on the bike up a steep hill. Specialized certainly can. I think the bike you tested may have had a defect.
Having said all of that you need to test ride the bike to ensure it meets your very specific needs. This will further limit your choices. Hopefully you have a good LBS to work with.
