TMH
Most (the strong majority?) of the E-MTBs which are out and available right now use pretty standard components regarding headset, stem, seatpost diameter, bars, etc., all the stuff you might need to change if the bike's geometry is not quite right for you from the factory.
Many of the better bikes you are looking at will likely have a somewhat aggressive riding position (weight forward and on your wrists) from the factory, as that is the most effective body positioning for their intended use.
So... with an e-MTB don't be at all surprised if they aren't immediately comfortable, although this is not something which cannot be inexpensively changed, starting with a standard $15 riser stem. Plus customizing is fun!
You may also want to open your search to a trekking style e-bike. Bigger tires then a city or commuter bike, but more upright riding position as compared to an e-MTB, but nowhere near as casual or laid back as a cruiser bike. They don't all feel like an anvil when riding, and can be nearly (almost) as lively as a good e-MTB. The R&M bikes you test rode may have felt like anvils to you, but R&M bikes are well known for their ride stability and rider confidence at higher speeds and for longer distances. So what you felt was actually designed into these bikes.
But then there is the issue of finding some nearby for a test ride. That can be more of a challenge than finding local e-MTBs to ride. Haibike trekking bikes are some of the best ones to check out, if possible.
You also speak of your son riding a fatty bike. There are some awesome fatties by Haibike (both hardtail and FS) and Bulls. I think that these bikes will also immediately have a more upright/less aggressive riding position as compared to a high end e-MTB.
